OctaneRender™ Standalone v1.0 beta3.02a [obsolete]
marcio_max
matej wrote:
marcio_max wrote:Benchmark GTX 670 4GB :)
Try pathtracing and PMC ;) (please :) )
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
jmfowler
Hi Marcus,
Do you have an idea when the 3.02+ SDK will be passed to jimstar so he can compile a kepler version for the maya integrated renderer?
I need this for a big animation I have to render out, the 680's are all sitting there just need the new maya update....
JF.
grimm
Thanks Marcus,
The driver is 304.51 (I have updated my sig).
I tried to load the spaceships ocs file. Once loaded I noticed that the number of tris was still at zero and once I clicked on the node the following errors happened:
CUDA error 700 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
    -> Kernel execution failed (dl)
CUDA device 0: Direct lighting failed
Are these ocs files out of date and too old? Are there newer versions available if this is the case? I'm going to do some more testing this weekend and try and figure out what the problem is.
Jason
abstrax wrote:The problem with libglew is weird. I really thought that we now link against static libglew - need to have a look tomorrow.
The error just indicates that the material preview fails. Could have many reasons. Which driver are you using?
Marcus
