Daz2Octane Beta released
Moderator: BK
Jay_NOLA
Thanks Tugpsx. I'll have to wait till it gets updated. Windows won't let me drag the window up any more so I can re-size it. in Studio 3 or Studio 4.
Tugpsx
Jay_NOLA wrote:Thanks Tugpsx. I'll have to wait till it gets updated. Windows won't let me drag the window up any more so I can re-size it. in Studio 3 or Studio 4.
Sorry for inconvenience will release a fix.
t_3
to temporarily get through this, you may use a layout manager like zmover (http://www.basta.com/Product.aspx?pid=11) it'll let you move the window to a negative screen position, high enough to reach the button...
The obvious is that which is never seen until someone expresses it simply
Tugpsx
Updated to fix saving preferences in DS4 and interface size.
Check first page.
bodenarr
can someone pleas post a blank oce-file
if have the strong feeling that I do somethink wrong
while creating one by myself...
what I have done:
- open octane
- save as
- empty.oce
Resolution 1024 x 600
importing OBJ in Octane does work
win 8 64bit / Xeon X3450 / 20GB RAM / quadro 600 / carrara pro8; Blender
http://www.on-sallmann.de / Germany / Rhein-Main
Tugpsx
bodenarr wrote:can someone pleas post a blank oce-file
what I have done:
- open octane
- save as
- empty.oce
Here is one that should be compatible with most versions.
However the steps you list above are the one used to create the Blank.ocs file.
-Start Octane
-select new
-select save as
-name the file
Blank.rar
Blank Ocs scene file
(3.39 KiB) Downloaded 488 times
Jadawyn2011
Hello Tugpsx,
after a while, I've found some time to test your plugin again, and now, more often than not, I got this error message when I launch the script:
"an error occurred while reading the file, see the log file for more details".
Checking log files, this is what I get that has some relevant information, probably:
Executing DAZ Script file: H:/DAZ 3D/Studio/My Library/Scripts/Utilities/Daz2OctaneFreeII.dse
Saved image: C:\Users\-----\AppData\Roaming\DAZ 3D\Studio4\temp\viewport.png
WARNING: Script Error: Line 2105
WARNING: TypeError: Result of expression 'lvi' [null] is not an object.
WARNING: Stack Trace:
<anonymous>()@:2105
Error in script execution!
Best regards
J
Tugpsx
Jadawyn2011 wrote:Hello Tugpsx,
<anonymous>()@:2105
Best regards
J
This occurs if no object is selected during export. It will be rectified in the next release.
Jadawyn2011
nope, I'm sure I've items selected, but it keeps stopping with that error
J
Tugpsx
Jadawyn2011 wrote:nope, I'm sure I've items selected, but it keeps stopping with that error
J
Will look into it. What version of Studio are you running.
Just tested with DS3.0 no problem.
Return to “DAZ Studio”
