OctaneRender® 1.025 b2.56 Test release [obsolete]
t_3
t_3 wrote:a minor problem i noticed in the last update:
sometimes after re-opening a scene misc floats (even if typed in) change in the last decimal place; i.e. 2.5000000 gets 2.4999999; seems to happen with position floats only. and also the position of some _nodes_ in the node graph editor change (so that they are i.e. 1 pixel below or above the last saved position). not really a big problem, but didn't happen before...
good news: i was wrong with this (at least the float problem), because in fact it's related to my spacepilot which sometimes changes the camera position if i put down something on my table :lol: thankfully there is a button to lock the viewport - really important in combination with a 3dconnexion device...
but i noticed something else lately: while having really large meshes with an awful lot of nodes, the _node inspector_ won't accept direct changes to "mesh-embedded" materials in the range of around 100 and up; connecting a material or macro to such nodes fortunately helps.
The obvious is that which is never seen until someone expresses it simply
Tugpsx
Is it just me not noticing, but just did a render that was set to stop at 16000 samples. The image wasn't what i was looking for so i decided to up the samples to 40000. Octane picked up rendering from that position. WOW! If I recall it used to start over from scratch or maybe i was impatient back then. LOL!
