Phantom Scatter 1.8 b-5 is now available!
Visit the website here:
http://scatter.phantomtechnology.nl/
» Fixed function INSET SWITCH
» Added function EXPORT DONE SOUND (found in the MAIN module). When this is set to ON, Phantom Scatter will play a sound when it is done exporting. This is useful when exporting really complex scatters, as it allows you to do other stuff while the export is cooking, and get notified when it's done. Then you don't have to constantly check the software to see if it's done anymore.
» When WIREFRAME is set to ON, Phantom Scatter will now show the detected edges of the currently selected scatter surface in orange (the lines are not affected by 3D depth so you will be able to see them very clearly). This only works when you have imported your *.OBJ model when INSET SWITCH was set to ON.
» Fixed a problem where certain edges did not apply the INSET correctly.
