Cinema4D version 2020.1-R7 (Obsolete stable)05.06.2020
rclassenphoto wrote:I get this Log error, if i move a object in C4d:
Started logging on 13.06.20 20:11:01
OctaneRender Enterprise 2020.1 (8010000)
CUDA error 719 on device 0: unspecified launch failure
-> failed to wait for event
device 0: path tracing kernel failed
CUDA error 700 on device 1: an illegal memory access was encountered
device 1: path tracing kernel failed
Any solution?
Make your hardware/driver combination more stable! Could you please ask to bepeg4d?
rclassenphoto
@aoktar
i have send a message to the Support team.
i dont unterstand why i get this errors....
rclassenphoto
But interesting...
now i get this error:
Started logging on 14.06.20 10:43:11
Mismatching barriers, 5 and 1
could not request a tonemap because we don't have any renderthreads available.
And then i get a black render image.
If i start the render Again it renders the scene correct.
rclassenphoto wrote:@aoktar
These are not about me, maybe about RTX?
rclassenphoto wrote:But interesting...
do you have NvLink active?
viewtopic.php?f=30&t=74794
ciao Beppe
rclassenphoto
Hi Bebe,
yes but i habe test it out. I use NVlink with two Titan RTX and i get this errors in Octane 2020 with C4D r21 and the new octane Plugin:
But i test it out to turn off NVlink and reinstall the driver without the NVlink bridge it does the Same. The errors Are Still be there.
This errors only Happend if i move a objekt in C4d with octane Live Viewer fired on.
Started logging on 15.06.20 20:13:31
CUDA error 700 on device 0: an illegal memory access was encountered
