OctaneRender for Modo 3.03.3 [STABLE]
I have refreshed the installers at the top of this thread with:
2.24.1.86
- Compiled with Octane 2.24.1
- Added command "octane.renderStatus ?" which returns true if the render has finished (ie. samples == max samples)
- You can now directly plug Modo Material colors into Octane RGB Color, Octane Greyscale Color and Octane Float Value nodes. See https://youtu.be/fN9H_x_pDpQ for details
- Fixed bug where only 2 (rather than Octane maximum of 3) UV maps could be used. Pls see https://youtu.be/rvuFI3okFwA for details.
v1adut
Hi Paul,
Does this version support batch render ?
Cheers
Vlad
Tharso
problem with select materials in modo sp2.
Tharso
problem with select materials in modo 901 sp2.
No - the octane.renderStatus command is the first step. I still need to add a command to save the viewport.
Can you be more specific pls?
Tharso
click in one material select other material, right after the new installation. Not always, but sometimes I need to close the render window and open again.
Can you be much more specific pls? Are the click on a material in the Viewport or the Shader Tree? If the Shader Tree, and you clicking a Modo Material or Octane Override? What specifically is not happening when you click the material?
sgtprobe
Yes, with 901 SP2 the render cache API is fixed, so fur works again in Octane!
Platform: Asus X99-E WS CPU: 5960X GPU: 2 x GTX Titan Black, 980ti Software: Modo, Octane for Modo, Win 10 Pro
Tharso
octane viewport
octane viewport
I'm sorry Tharso - this is not enough information for me to be able to reproduce or fix your issue.
Return to “Foundry Modo”
