Version 2.24.2-TEST6 - Test only
fuchsundvogel
aoktar wrote:
Can someone try this version for problem?
https://render.otoy.com/customerdownloa ... .1-win.zip
see screencap for explanation
attributemanager behaves strange when working with materials. it doesnt change to the values of the selected material, when you select another material.
when no material is selected before all is ok
material_attribute_manager.mp4
(817.77 KiB) Downloaded 3535 times
fuchsundvogel
i have a texture projection XYZ to UVW in worldspace
when i want to rotate this projection only Z works. X and Y values are ignored.
when i open this scene in standalone all values are working.
rotate_texture_scenefile.zip
(679.19 KiB) Downloaded 237 times
rotate_texture.mp4
(14.41 MiB) Downloaded 3530 times
pxlntwrk
i confirm that copy/paste mix mat have some trouble with amount connection.
When i copy a mix mat with float in amount slot, it stay connected in copied scene, but if i use a noise for example , it will not..
after some test i cant say, its a bit arbitrary :?
pxlntwrk.net
fuchsundvogel
win7 / R17.032
undock nodeeditor from layout breaks gui
dock_nodeeditor_in_layout.mp4
(1.84 MiB) Downloaded 3754 times
pxlntwrk wrote:Hi,
Which version? I can't see this. It copies as should be. Where the texture stored? In mix material or another materials?
For copy/paste mix material problems, i can't promise to sort all. You should be happy as we did. C4D has not any support for mixed/linked material systems. So it's impossible/hard to solve every problems. I'll fix preview issue after copying, but if still don't make correct previews, you should click to preview icon. This will force it.
Yambo
Only the value (image texture / float texture / rgb spectrom) that drive the mix material amount is causing problems. It copies buy disconnected.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Only the value (image texture / float texture / rgb spectrom) that drive the mix material amount is causing problems. It copies buy disconnected.
I can't reproduce. A simple scene would be great.
fuchsundvogel
copy / paste objects with mixmaterials works here with the latest build
fuchsundvogel wrote:win7 / R17.032
I don't know why this happen. But i suppose that's not necessary report. When you resize it's fixed. You'll never use it unresized after undocking.
