******* Wishlist and feedback topic ********
VVG
Is it possible to add GaussianSpectrum load/save palette?
or basic color slider
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
zinogino
Slight Changes to the IPR
Possibly add a scale and zoom to replace the lock resolution? I find the lock resolution troublesome and clunky compared to other IPR's.
Another thing is I found there's a slight visible on the bottom part which is not major but annoying in some scenes.
zinogino
Instead of having the camera, material and lights checker in the options tab, can it be icons which are easier accessible in the IPR?
guigui441987
Hello
The Octane AI denoiser will be available in the next version of octane for c4d plugin ? soon ? when ? :)
Thank you
y81r
Hi Ahmet,
it would be awesome if there is a way for object based glow (bloom/glare) checkbox in a tag (disabled or enabled).
for example a scene with three lights but just one light and a sphere with a blackbody emission material effected by glow post processing.
Regards
Yassin
Hi y81r,
since the Post Effect is applied on top of the render, if you want that a light is not affected by the Glow/Glare effect, you need to reduce the power of that light. So it is not possible in one shot, but since you need only 32/64 sampling for a good Post Effect pass, you can change the power of the lights, and render only the post Effect in a second pass.
y81r
Hi beppe, thanks for your feedback!
yes that's the workflow and so I'm doing it right now,
it would just be a lot easier on an on off switch and it would provide so much more options.
too bad if its not technically possible.
Regards
Yassin
Elevux
I would LOVE LOVE LOVE a button (quick node) in the DIFFUSE/NORMAL/SPEC/ROUGH ets that says :
"IMAGETEXTURE "
as i am alway going into the channels to pick OCTANE/IMAGE TEXTURE.. i do this alot and going to the menu every time is tedious
Similar to the Displacement channel.. where i can click the button to add the node... for quick image material setup
Also in the Node editor i think Alphabetical would be better... im always trying to find a node in the list!!!
Thoughts?!?
Thank you!!!!
haffy
Whitebalance pipet like Modo / Octane have, like the Focus and Material picket in the Live viewer.
Photographic exposure override with a checkbox, to controll image exposure with shutter speed, aperture and ISO.
3D Generalist.
byMELT
Hey Ahmet, thanks for all the great work!
The particles (Octane ObjectTag) in x-particles don't scale via Particle Scale parameter, only via Particle Radius. Because of it, there's much less what we can do about them. i.e. we can't scale them only in one axis.
Right now I'm looking for a workaround :)
If you'd like to improve on x-particles integration, just let me know. We can help and test :)
Best,
Kuba
Return to “User requests”
