OctaneRender™ for LightWave™ 2.0 DAILY BUILD
sigmamoon
hello juanjo
i d like to know if the octane checks texture could be applied to the bump glossy and diffuse materiel cause to my part, doesn t work.
thank you
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
Godstrike
atnreg wrote:
Godstrike wrote: Have you tried MSI Afterburner? Works a treat on my 2 x GTX 590's and 2 x GTX 580 3GB's. When I set my rig up for a big render I dial the fans to 85% and also turn up my PCI fan controller to maximise air-flow through the case. I get about 80 - 85 degrees on average.
No I haven't but it seems to be for certain MSI cards only. Mine is Gigabyte :)
I also downloaded EVGA PrecisionX which has similar features. Thanks for the tip anyway :)
Sure thing, although it works fine on my Asus, Zotac and Gigabyte cards. AFAIK it's not limited to MSI cards only:)
I am using version 3.0, and version 4.0 has just been released.
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
BorisGoreta
Whenever I overclock TITANs they render without problems but here and there my 3D locks up ( for using OpenGL I guess ), maybe I should overclock all other cards except the display card.
atnreg
Oh, ok, then I might try it, the EVGA software is confusing and complicated because of the 'fancy' graphical interface. Why these software need to look like some game? :x
Afterburner looks much cleaner, thanks for the tip :)
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
juanjgon
sigmamoon wrote:hello juanjo
thank you
The checks texture can't produce a bump map, the black and white checks don't have a local gradient to make possible a bump effect. You need a texture map like a grid, perhaps something like this:
http://www.thebest3d.com/dogwaffle/lua/ ... d800b4.jpg
atnreg
atnreg wrote:
Godstrike wrote:Have you tried MSI Afterburner?
WOW Afterburner is great! It is very customizable (almost too much, it takes long time to get all the icons and monitor config as you want and customization is a bit complicated :D) and it can even show the monitor values or even graphs on my 3DConnexion Spacepilot Pro LCD display :o
Thank you very much!
Antti
juanjgon
BorisGoreta wrote:Please add surface picking for instances too. Thanks !
This feature is ready for the next beta release ;)
BorisGoreta
Fantastic, this made my day, in fact, a whole week ! :D
juanjgon
BorisGoreta wrote:Fantastic, this made my day, in fact, a whole week ! :D
In theory now picking should support pick surfaces in the instances, or pick over any kind of camera configuration (orthographic, lens shift, perspective correction, etc.)
sigmamoon
thank you
Thanks juanjo, i did that, but it could be so fun to directly use the check texture (quicker).
I have an another request
I have some problem with "cast shadow" of the lights
it s always ON for me , even if i uncheck the option. Is it only my way (i use the 2.6.1 version)
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
Return to “Lightwave 3D”
