Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
iRota
Hi, let me make a suggestion, I think you should change the MAC OS CUDA 9.1 reccomendation on the first post and update it, as the only CUDA version apparently working under MAC OS is Mac CUDA 418.163:
viewtopic.php?f=14&t=70885&p=395885&hil ... 30#p395912:
bepeg4d wrote:Yes confirmed, from 2020.1, if I remember well, since it is based on CUDA 10.2, you need to have Mac CUDA 418.163 and latest Mac Nvidia GPU driver for 10.13.6:
https://www.nvidia.com/en-us/drivers/cu ... 163-driver
ciao Beppe
Thank god I just found this post, in the meantime I have spent a few hours of my work going mad over this.
Thanks.
ñgo
macOS 12.7.6 (21H1320)
AMD RX6800 XT + Radeon Pro XW 9100
pxlntwrk
Awesome release !! thanks
pxlntwrk.net
Please do not make any other critisms or requests about "copy denoised beauty" and sRGB combination. It had to be like that and it's like that since previous RC builds. Nothing new. I'll look it again if there is some easy and solid solution to bring it back. Until that use linear or aces srgb colorspaces with a post effect to convert it to SRGB. I'll be away for one week so can't help much in this period.
VVG
aoktar wrote:Please do not make any other critisms or requests about "copy denoised beauty" and sRGB combination. It had to be like that and it's like that since previous RC builds. Nothing new. I'll look it again if there is some easy and solid solution to bring it back. Until that use linear or aces srgb colorspaces with a post effect to convert it to SRGB. I'll be away for one week so can't help much in this period.
When can we expect the improved XP integration that Jules talked about? (XP SDK open for Octane)
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
gohmn
This release has some major issues for me. Not sure why by I'm getting hard crashes every time I click render. Usually happens at the end of render when trying to save to disk, but sometimes at the beginning too. Attaching a few of my crash reports.
bugreport_20210210_130515.zip
(1.4 KiB) Downloaded 197 times
bugreport_20210210_133709.zip
(1.4 KiB) Downloaded 201 times
bugreport_20210210_083240.zip
(1.41 KiB) Downloaded 209 times
thanulee
Heya, great release!
- I have problem with the compare render buffer. The line goes from vertical to horizontal very easily and the mouse pointer doesnt stick in place, making it unusable like this.
- The "rename" in compare doesnt work here.
Thanks a lot !
Secretwoodsrl
This new version has a lot of new features, thank you!
However I found a strange bug with C4D. If I make an animated preview using the viewport rendering with the tool "Make Preview" (Animate -> Make Preview), the first seconds of the preview will render black, depending on the lenght of the preview. I don't know what is causing this issue, but I have it in a lot of scenes and it can't be recovered. By switching to the previous octane version all work good.
Maybe is something related to the changes of the opengl materials?
Secretwoodsrl wrote:This new version has a lot of new features, thank you!
Possible, opengl previews are generated by background processes. Will check next week
Kalua
Hello, Aoktar
As soon as I create and start tweeking with Toon shader, Octane crashes - please refer to .gif.
This error won't happen within Stand alone.
Regards,
C4D 2025.1.1 v1.8.4 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
CCIDgfx
Hi Aoktar,
Looks like Store Render Buffer isn't working. Nothing shows up on the right when I change anything.
Regards
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
