OctaneRender™ 2020.2 RC1
mojave
funk wrote:BUG: HDR images with large dynamic range render incorrectly
This is another older one from this thread: viewtopic.php?p=377892#p377892
It still happens in 2020.2. Octane is clipping HDR images even when manually setting the texture import type to 32-bit:
You can see the "sun" in the HDR image is being clipped. The blue sky is becoming just as powerful as the sun, making the render look too blue.
As mentioned by Karu here this is currently a limitation which needs to be solved by adding support for 32-bit float HDR textures. Since this version is feature locked we won't be able to add this to 2020.2 but in a future build.
funk
mojave wrote:As mentioned by Karu here this is currently a limitation which needs to be solved by adding support for 32-bit float HDR textures. Since this version is feature locked we won't be able to add this to 2020.2 but in a future build.
Yeah I remember his reply, but since it was a while ago (7 months), I wanted to bring it up again in case it was forgotten. I feel this is kind of important.
I also replied to his post here: viewtopic.php?p=380243#p380243
nejck
+1, I also find it to be an important issue. :)
mojave
We are taking note of this. Thank you both for your feedback.
enricocerica
Chaos Texture doesn't seem to work when used on normal pin, is it a expected limitation ?
http://www.myline.be
