OctaneRender™ 2019.1.1
vijay
funk wrote:BUG: Displacement causing shading normals on other materials to be faceted?
I'm running into an issue where having displacement on a material on 1 mesh, causes materials on other meshes to become faceted
1. Load the orbx and select the render target to render
NOTE: The 2 teapots look faceted
2. Disconnect the "displace%Default" material/nodegraph from the abc node
RESULT: Now the smoothing on the teapots is correct (smooth)
Please let me know from which plugin did you export this scene?
funk
I use the modo plugin
J.C
New edges rounding has shading errors compared to eg. Cycles implementation.
This faceted look happens on all types of meshes.
System – Windows 11
useruser
hello,
something is going wrong with the slave-installer ( win 10)
i got this errormessage:
i have one all-acess licence, so one slave is also included
thanks in advance
edit@ i disabled the old active v4 licence on the slave-workstation, now it works.
edit2@ it works exactly one time, restart the slaveworkstation and now the errormessage appears again:
the latest RC3 worked also with the slave-workstation without problems. this "stable"-version not.
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
Jolbertoquini
J.C wrote:New edges rounding has shading errors compared to eg. Cycles implementation.
Hi JC,
Interesting did you set on accurate not the fast? maybe paste the orbx for the dev to see :)
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Greg
These edge rounding errors happen on virtually every model, even very simplistic ones. I has to work on curved surfaces, not just cubes.
-Greg
MODO left, Octane right (thx)
CEO Sabertooth Productions
Co-Founder Pixel Fondue
Lewis
Greg you probably mean the other way around, modo LEFT side, octane RIGHT side?
BTW i found that Octane 2019.1.1 is slower than octane v4.05 so that should be another thing which DEVs should fix/optimize.
check for test scene here:
viewtopic.php?f=23&t=72803
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
J.C
Hi JC,
JO
Hi JO, it's set to accurate. Happens on all curved meshes.
System – Windows 11
funk
I made a copy of Greg's rounded edge example in case the devs need an orbx
Elvissuperstar007
the render worked at night, then it didn’t work anymore
octane render 3ds max 2018.1 2019.1 1019 .1.1
NVIDIA 1080 GTX 8gb 64 GB DDR 3 CPU memory 6Gb
nvidia 436.48
users with a regular V4 license 2018-2019
https://www.dropbox.com/s/q8mo8u8eblheg ... R.rar?dl=0
