OctaneRender® for 3ds max® v4.00-RC4 - 6.07 [OBSOLETE]
paride4331
coilbook wrote:Why does octane label materials in curve editor wrong? It calls my second material RIPPLES as displacement even though displacement slot is empty. And first material is called AMOUNT. I think this is the reason I had hard times writing script for car stop lights and it had error with names because octane assigns them wrong
Hi coilbook,
thanks for your report, I checked it and sent to developers.
Regards
Paride
Goldisart
6,1 Octane - Ok ...... this work
https://yadi.sk/i/tCzf3_UqiSouPw
paride4331
Goldisart wrote:6,1 Octane - Ok ...... this work
Hi Goldisart,
I tested your issue running 5x 3dsMax and 5x Octane render, Everything goes smooth.
Of course, when your Vram is saturated Octane 3dsMax give GPU failure message.
Regards
Paride
Goldisart
Hi Goldisart,
Regards
Paride
thank you then the problem is in the system, Windows 10
paride4331
Hi Goldisart,
Regards
Paride
Win 10 eats about 20% VRAM all GPUs on board and it's not Octane.
Regards
Paride
Goldisart
paride4331
I was unable to run the third project in win7 .... I beg you to explain the update version where now there is a distribution of memory cards.... I would like to cut for example 25 percent to give on each project that there was no redistribution of memory of the video card. My ultimate goal ... what would 4 projects at the same time rendering the same scene .... in this case, all video cards are loaded at 100%
4 launch I'm doing for an animation that would be faster to count the frames .
now I run 2 projects the third hangs .... although the memory cards still have a lot of free space
https://yadi.sk/d/6UxYczBb63LGJA
Mb Asus X99-a2 Nvidia 411.70 GTX1070tix2
Goldisart
Hi ! Tell me how it works ?
https://yadi.sk/i/vIjoZ1eTSDR-qw
paride4331
Goldisart wrote:paride4331
Hi Goldisart,
you should be able to run more than two Octane render at the same time; try reducing parallel samples to 2, then incrementing step by step and/or or use CPU memory using GPU head room at 512mb.
Regards
Paride
Goldisart
thanks everything works
paride4331
Goldisart wrote:Hi ! Tell me how it works ?
Hi Goldisart,
the correct workflow is like in the screenshot; the options you show refer to SDK workflow, I will ask developers to to remove them.
Thank you.
Regards
Paride
