Version 3.07-R2 (previous stable) update on 01.11.2017
Yambo
:D
i looked for it anywhere else besides that.
Thanks, Ahmet.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
rodross
Rotating HDRs in the OctaneSky object seems to be broken, on my end. Version r19.024, 3.07-R2
rodross wrote:Rotating HDRs in the OctaneSky object seems to be broken, on my end. Version r19.024, 3.07-R2
Was it working on R1?
rodross
Skipped R1, went from 3.06.x stable to this one.
Could you try? Im away for one day.
Silverwing
Yes I can confirm. HDRI RotX and RotY functionality is broken in version 3.07.R2 (It definitely was working in R1)
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
BCres
1. The "bind all" check box works now when you open and close C4D to reestablish communication with the slaves.
However, it still does not communicate with the slaves when running the commandline version of Cinema 4d. This worked for all the versions prior to 3.07 and is my preferred way to work.
**Edit** Okay I found a fix for this. Instead of running commandline.exe from the Cinema4d folder, you neeed to run Cinema 4d.exe with the -nogui switch. Then all of the slaves are used.
So a sample commandline from the desktop would look like this:
"C:\Program Files\MAXON\CINEMA 4D R19\Cinema 4d.exe" -nogui -render "T:\your folder\your project.c4d"
(Quotes are necessary and the T: is just the letter I happened to use)
2. When exporting to an .orbx file via the LV menu, NO FILE is ever written to the hard drive. I tested this on R18 and R19 and several different drives. I can't make .orbx animated files now in C4D.
Hope you can fix these. Thanks.
mustardseedsg
Yes I can confirm this occurs on Mac OS X as well. It was fine in R1. UV Transform in ImageTexture node also doesn't work in R2.
Silverwing wrote:Yes I can confirm. HDRI RotX and RotY functionality is broken in version 3.07.R2 (It definitely was working in R1)
Mac OSX 10.12.6 / MBP 15" w Touch Bar, 16GB / Mantiz Venus Thunderbolt 3 enclosure with GX1080 / C4d r19 Octane
Hi guys,
about the Environment rotation issues, in the meantime, enter in the Imagetexture node, create a Projection node in Spherical mode, and change the rotation values:
Add a default transform to imagetexture and it will work as i can see. I'm looking for a fix.
