Test Version 3.07-Test6a
rleuchovius
Thank you for the update!
However, I'm getting some random crashes in R19.
Right now it has worked for a while, but I had 3-4 random crashes this morning while moving texture nodes in the node editor.
My colleagues had similar problems.
Any idea on what causes this?
Cinema 4D Freezes (seemingly at random) while working in the node editor with a live viewer open.
rleuchovius wrote:Thank you for the update!
How can we know without investigating that?!! Best way is to narrow down the things until find that and also defining crashes. What's crashes do you mean here? C4D app. or render failures? Any bugreports?
rleuchovius
It has actually worked fine for many hours now, I will search the logs if it happens again.
spex
Any chance of an OctaneVR version?
bertritude
Hi guys,
About "Floor object support added. Tiling from texture tags will not work. So use transform nodes in textures for scaling", it works on R19 demo but not in R18 on my computer.
is it normal ?
thanks
florianbaumann
hello aoktar,
my multipasses are getting rendered, but not saved. can't get it to work. is this a known bug?
florianbaumann wrote:hello aoktar,
You talk about R19? It's not a bug for me. I think R19 sdk has some problems on saving bitmaps. I've asked to MAXON.
spex wrote:Any chance of an OctaneVR version?
VR versions will be available when we released new stable builts.
florianbaumann
yes i'm talking about r19
miohn
Maybe the resulting PSD exceeds 2 GB?
Try using the PSB Format.
Had similar problem last time.
regards
Mike
