OctaneRender™ Standalone 3.07 TEST 6
abstrax
coilbook wrote:what about noise from lights when using volume medium in the medium tab of the sun. Will this be fixed? Basically dark environments, fogs and lights and it is just a noisy mess. Why can CPU rednerers render it clean and octane still struggles with volume medium and lights
Thank you
Could you send me an example scene? We can then have a look. Thanks.
BorisGoreta
I can second that, environment medium and lights = noise never goes away, I render 2x or 4x resolution and scale down to get rid of it.
coilbook
Thank you
Hi Abstrax
here is the file with noisy medium. It is a max scene. When you start rendering you will see noise never goes away especially near lights where it is the brightest, Maybe you guys can fake it somehow or improve it. Plus volume step length does not work in volume medium
I think future releases should have a real optimized fog system like other renderers have and not just a sphere around your scene with volume texture.
Thank you
noisy medium.zip
(40.53 MiB) Downloaded 369 times
BorisGoreta
Here is a perfect example of this problem, rendering is at 40000 samples alerady and many hot pixels just stay there in the medium, plus the area around the light is super noisy too.
Lw and orbx scenes are attached.
light medium noise.rar
(11.27 KiB) Downloaded 299 times
divasoft
+1 for medium denoising optimisation.
Daniel79
Maybe is a bug or i wrong something?
The shadow catcher don't work (all enviroment)
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
abstrax
Daniel79 wrote:Maybe is a bug or i wrong something?
Are you sure that you are using 3.07 test 6, because there was import issue in 3.07 test 5 where Alembic files got imported with the incorrect winding order, which got fixed in test 6. If yes, could you please send me the scene? Thanks.
Daniel79
yes i installed now the last version 3.07 test 6..
the scene is 115mb i can send you a dropbox link?
abstrax
Daniel79 wrote:yes i installed now the last version 3.07 test 6..
Yes, please send it to me via PM. Thank you.
abstrax
Thanks for the scene. It seems the normals are exported incorrectly:
Currently, the shadow catcher calculates the shadow it receives on the front face, i.e. the side of which the normal points away. In your case that would be the shadow that is received on the underside of the floor plane.
