OctaneRender for Carrara 3.08.03.42[Stable and Test]
Hi Simon,
Would it be possible to accept empty VDB files? Works well in OR Standalone, but Carrara crashes.
Best wishes,
Thomas
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Empty vdb example: https://www.dropbox.com/s/47pcbpmkaldayag/empty-vdb.vdb
Uh, that was fast. Thx
Loading in empty VDB files works, but in Animation mode, there is a problem. If I have an animation with empty VDB files and I slide to a filled VDB file and afterwards to an empty file again, the OR Viewer does not update. That is, I still see the filled VDB file in the OR Viewer. I hope you understand what I mean
Sighman - Happy New Year! Not an issue, but a request. I have been working recently with surfaces which have a texture map in the glow/emission component. I need to set these up with Carrara's shaders but would ideally like them to render in Octane Render too without having to adjust them all each time I render - there are a lot! The default conversion from having a texture in Carrara's glow channel into Octane's Emission channel seems to give a very low value for the emission, of 0.03, which is almost equivalent to having no emission at all.
Would it be possible to have a look at this and change the default translation from Carara shader's glow to Octane Material's Emission to something that looks broadly equivalent? Also if there is a multiplier on the Carrara side, so Multiplying a texture map by say 250%, could you use this to adjust the strength of the Emission automatically in Octane?
I hope this will be an easy task and something that you can build into the next major update. No worries if not, I can do things manually, but having a good automatic translation would be a real time saver (and hopefully useful for other Octane for Carrara users as well!).
