The problem of Octane and Rhino IOR 1
Also we could think about the transparency. The specular transparency threshold is a nice feature. Could you use the diffuse color for the glass material? Transmission color = Rhino diffuse color?
Adding rules on-the-fly is going to make this a lot more work than it need be. Once you have a complete set of the material conversion rules you want applied, pls let me know and I will code them into the plugin.
Micha
* Octane IOR = Rhino IOR + 0.01
* Octane roughness =1-100/gloss finish
* Octane specular = Rhino reflectivity / 100
* Octane transmission color = Rhino diffuse color
Also you could check the texture multiplier. It looks they are not connected, I can set bump textures at 0% and 100%, no difference, same rendered look. If you like you could also connect the disable/enable flag of the Rhino textures.
At this point I stop, no more ideas how to connect the Rhino material to Octane.
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
I could not see a way to get the multipliers from the Rhino API - so I have posted the question on the McNeel forums.
Return to “Rhinoceros 3D”
