OctaneRender™ Standalone 2.13
Dom74
Rikk The Gaijin wrote:Thank you guys! The script now works, but the multi-layer EXR is still empty. For now I can use the PNG, so I'm good, but you might want to check it out...
Same for me, I have tried pro exr trial for Photoshop cs5, alway get a black screen, must be something to do ?
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
voon
Is the 980 back to 780ti level now in octane?
smicha
voon wrote:Is the 980 back to 780ti level now in octane?
It is not, it never was. But 980 is faster than in 2.12.
Seekerfinder
Small request... could we please not be asked to save an OCS file if we made no changes to it?
Seeker
abstrax
Seekerfinder wrote:Small request... could we please not be asked to save an OCS file if we made no changes to it?
Seeker
You won't be asked if you made no changes. As soon as you make a change, the project is flagged as "dirty" (indicated by a star in the window title). Be aware that even just moving a node is a change.
stratified
We did a quick test with OpenEXR files exported from OctaneRender into Photoshop (CS3):
  • If you export multiple render passes from Octane into a single EXR file (these are called layered EXRs) and try to open the file in Photoshop it will give you a black image. You need to install the commercial ProEXR plugin to load the multiple layers as photoshop layers.
  • Plain vanilla EXR files from Octane work just fine in Photoshop. You can get these by either exporting the render passes as discrete EXR files or by saving out the image directly from the viewport.
cheers,
Thomas
Dom74
OK, thanks.
Seekerfinder
Seeker
Ah! Right you are. It's a rather sensitive affair then.
Best,
Seeker
Seekerfinder
stratified wrote:We did a quick test with OpenEXR files exported from OctaneRender into Photoshop (CS3):
cheers,
Thomas
Very useful, thanks Stratified. Looking forward to the PS plugin...
Seeker
Tugpsx
Thanks for update
