Easy way to convert regular surfaces to Octane?
3dworks
thank you very much - big step into right direction :-)
gordonrobb
Very good idea. Any movement on the (load image) option so that an image becomes available from the drop down?
sigmamoon
As you know, now the V2 plug can convert procedurales lightwave in octanerender (on the fly)
i must test it soon
WebSite compagny
Pixel De Lune
WebSite personnal
SIGMAmoon.com
gordonrobb
Be aware it's not converting the procedural as such. It's using the LW procedural to create an image (the resolution of which you set), and it is applying that image in UV space. It is a superb solution, but not quite procedurals on the fly.
3dworks
take in mind that a converted procedural is a simple texture. as such it has a limited size and a border which usually is not seamlessly tiling...
Return to “Lightwave 3D”
