OctaneRender® for 3ds max® v1.31[Test]
kevinshane
Thanks Bicket
And thanks Kevin for the video.
Waiting for it. Actually I need your video to understand hahaha
OK here is the link:
http://render.otoy.com/forum/viewtopic.php?f=9&t=38267
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
RobSteady
Thnx Bicket & Kevin!
Now someone at Otoy only needs to copy the magic forumula and implement it into the plugin.
Would also be great if the resolution stays the same and everything else but the region stays black...
Please? :roll:
nildoe
OMG!
Bicket and Kevin this is great!!
thx so much! please Scripters PLEASE Help the comunity by doing a script that can automate this!
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
dawe
I´m not sure if this is a bug or if it is deliberate change from 1.25 to 1.31: I noticed that when I render to .exr 16 bit half float it saves to different gamma. the 1.31 version is much darker. I have to upp the gamma to about 4, in post, to get it the same as the 1.25 version. And as it isn´t full float, the colors will crack..
could someone pleas confirm this?
//Daniel
anifex3D
I just tested some very heavy scenes (4.5gb of vram being used) with this release and the latest NVidia driver 334.89 and everything was stable. I am using a 2 monitor setup rendering on one monitor with 2 titan cards and then using a 3rd titan card shut off from rendering and the other monitor to work on and adjust materials in the slate editor that has hundreds of materials and everything is working great.
https://anifex.com/ | Win 10 64Bit | i9 - 9920x -128gb ram | 4x RTX Titan 24gb | 3dsMax 2022 Octane Plugin
dawe
It´s definitely something wrong with the exposure/gamma with this version compared to earlier versions. I had to revert to 1.25.. this is in max 2014! dont know about 2013.
//Daniel
anifex3D
I just saved as an .exr 16 bit half float in 3ds max 2014 and I had no change in gamma vs the previous versions. Not sure what could be wrong.
dawe
anifex3D wrote:I just saved as an .exr 16 bit half float in 3ds max 2014 and I had no change in gamma vs the previous versions. Not sure what could be wrong.
Anifex3d: Did you uncheck apply tonemapping for output?
anifex3D
No - tone mapping was turned on. We typically do not work in the linear mode so I can not verify that. Sorry for the confusion.
anifex3D
Wow - something is definitely wrong with the tone mapping turned off. It is as you say about 4-5 times darker.
Return to “Autodesk 3Ds Max”
