poser plugin animation rendering problem
You write that "When the plugin moves the Poser frame from say frame 1 to 2, Poser is not applying the joint control morph to the figures vertices."
But when the plugin moves the Poser frame from say frame 1 to 2, in octane window "View port" all ok
But when the plugin moves the Poser frame from say frame 1 to 2, in octane window "Animation" happening problem. When this happens the Poser preview window also showing these)
In oldest version plugin, trouble to bee in both cases!
You could fix half by programming.
Now we need to do to something, to that works in the window "View port", worked in Animation" window
Have you tried the suggestions I posted above?
denver2
I underclocking my card ( 75% and 50 % of it's normal speed).
-No result. All the same
"ticking "Refresh Scene Each Frame" in the Animation tab"
TY.
The fact that the Poser Preview window is showing the tears too hopefully demonstrates that this is a Poser bug, not a plugin bug - so it is not straightforward to code around. The fact that I cannot reproduce the problem on my PC makes it even harder!
I will upload the next version of the 1.23 version in a few hours - and it contains a small modification to the way the plugin advances the Poser frame during animation - which /may/ help.
I am reasonably certain that using your on-board graphics card as your display adapter will solve the problem too.
denver2
a little clarification
When this trouble is happens, the Poser preview window also showing these In oldest version plugin, bot In new version plugin, trouble in octane window, not showing these on the Poser Preview window
I have uploaded a version with a small change which /may/ assist with this issue. If it doesn't - I will need to talk to Smith Micro about a fix in the next SR of Poser. As stated before, using you on-board graphics or a second graphics card as your Windows display adapter will most probably also fix this issue.
http://render.otoy.com/forum/viewtopic. ... 09#p165709
denver2
Sadly, installation of a new version of the plugin is not solved the problem
OK - suggest you investigate the "on board graphics" option. If you motherboard has an onboard graphics card - use it (might need a BIOS change and a reboot) - suggest you Google your motherboard model to see have to do this.
Other quick thoughts : Re-install Poser and the SR's (can be reinstalled over your existing installation). Also you can try installing Nvidia drivers 327, since there have been some issues reported with driver version 331.
I will log a support issue to Smith Micro. It's going to be hard to resolve - because unfortuantely you and the only person experiencing the problem, and if they (like me) cannot reproduce the problem, it's very hard to resolve.
denver2
Re-install Poser and the SR-s Pack1
Re-install Poser and the SR-s Pack2
ch0pper
not sure if you on Poser version pro 2014
but service pack 3 is out
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
denver2
-install Poser SR-s Pack3
Return to “Poser”
