OctaneRender™ Standalone 2.12.1
aLeXXtoR
Info Passes are still don't have neither Motion Blur nor DoF. Is this behavior is normal?
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
stratified
You need to check distributed ray tracing in the render passes node, it was already there in the previous release.
aLeXXtoR
stratified wrote:You need to check distributed ray tracing in the render passes node, it was already there in the previous release.
Elephant wasn't seen by me... :) Thanks!
WebSite
Showreel
Rikk The Gaijin
abstrax wrote: [*] Fixed/improved displacement mapping with negative offsets.
Thank you for this update! I can see there was an improvement in the displacement, unfortunately the problem is not completely gone, although is much better than before. ;)
I've noticed that if I apply one level of Subdivision, the black lines become almost invisible, so definitely an improvement! 8-)
aLeXXtoR
Is it possible to add a Search field to the API Browser?
And it would be really great if there was an option to have a kind of "extended hints" for elements with theirs "API paths" (like in Blender for example).
WebSite
Showreel
Rikk The Gaijin
Oh, I forgot, I like the new compact interface! 8-)
aLeXXtoR
Rikk The Gaijin wrote:Oh, I forgot, I like the new compact interface! 8-)
Oh, yes! Me too! :)
WebSite
Showreel
smicha
:o :shock: :D
PMC speed increased from 9.43ms/s (2.11.1) to 21.80ms/s (2.12). Where is the trick?
abstrax
smicha wrote::o :shock: :D
2.11 was too slow. Compare with 2.06 and 2.10 and you see what I mean.
smicha
Right. 2.06 scores 25ms/s; 2.12 almost the same with path term power set to 1. Thanks Marcus.
