OcDS FIRST RENDERS - FIRST PRIDE :) post here...
Moderator: BK
Banti
Looks very nice. I really like the teeth and sclera shader. All of them Random Walk / Specular materials I guess? Also what depth settings do you use in you renders settings?
Sorel
Banti wrote:Looks very nice. I really like the teeth and sclera shader. All of them Random Walk / Specular materials I guess? Also what depth settings do you use in you renders settings?
Yup, it's all random walk with specular transmission. As for depth settings, I assume you are talking about the diffuse/specular/scattering depth? I keep those at default.
Banti
Yeah I was talking about the diffuse/scattering depth. I usually use diffuse depth of 16 because at 8 the skin can be rather dark in some scenes. Especially interior scenes where I cannot light with HDRIs
Sorel
Banti wrote: Yeah I was talking about the diffuse/scattering depth. I usually use diffuse depth of 16 because at 8 the skin can be rather dark in some scenes. Especially interior scenes where I cannot light with HDRIs
Ohh I'll have to take a look into that.
Banti
In my experience, a diffuse depth of 16 is the maximum at which the brightness will increase. Anything more than that is pretty much useless and just increases render time for no reason.
When you light your scene with only an HDRI its usually not necessary to go above a depth of 8 as there is more than enough light coming from everywhere. Also, when you increase the diffuse depth,
you will find that sometimes parts of your skin will look too bright or too saturated, you probably need to adjust them via color correction node.
I am currently working on a "non random walk" skin shader because Octane has so many problems when working with Random Walk, and especially in specular material, that I am willing to take a cut
at the realism to spare me the hassle.
Sorel
Banti wrote: I am currently working on a "non random walk" skin shader because Octane has so many problems when working with Random Walk, and especially in specular material, that I am willing to take a cut
I'm curious, what problems have you been experiencing? I wonder if I've been oblivious to some of them lol.
Banti
Well the most obvious one for me is the facetting issue. Having your model at anything below subdivision level 3 will make the facetting visible on your character.
But having multiple models with subD-level 3+ will make your viewport incredibly laggy.
The "fake shadow" option (which is necessary in pretty much all cases) uses some sort of bias in its calculation which can cause your material to turn extremely dark when using many light sources. This is especially visible when those light sources have an opacity of 0 (basically when you hide them). You can test this by having a light plane in your scene that does NOT directly light your character (basically turn the light away from it) and then turn up this light to a very high brightness. Your model will turn completely dark at some point.
And then there is the fact that this kind of material takes about 3 times as long to render when compared to simple diffuse shaders.
Sorel
Banti wrote: Well the most obvious one for me is the facetting issue. Having your model at anything below subdivision level 3 will make the facetting visible on your character.
Ah yes, the faceting. I wonder if that's something otoy will ever resolve. I was unaware of the fake shadows thing. I've also tried diffuse shaders but I could never get over them not looking right to me. I suppose I could give it another go eventually. Do you have any tests of what you're working on?
Banti
Sorel wrote: Ah yes, the faceting. I wonder if that's something otoy will ever resolve. I was unaware of the fake shadows thing. I've also tried diffuse shaders but I could never get over them not looking right to me. I suppose I could give it another go eventually. Do you have any tests of what you're working on?
Well I wouldnt hold my breath for a fix to be honest...
Most of my skin test renders are nude body shots and I am not sure about the nsfw policy on this forum.
But I guess I can link it without posting the image
https://imgur.com/a/x6UEPUE
If this is against forum rules I will dm you the link again
Sorel
Hey that actually looks pretty good! Nice job.
Return to “DAZ Studio”
