Non-offical Blender 2.56 plugin
neutrinox
How to setup "Octane Binary" in "Octane System Settings" for mac?? I used "/Applications/OctaneRender 1.024 beta2.44 CUDA 3.2.app/Contents/MacOS/octane" but nothing happened.
yoyoz
What do you mean by 'nothing happened'?
You should anyway better ensure you have no space or special character in the path (for every path/name in fact).
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
dave62
i think he means that nothing visual happens-> export works at all but octane didn´t start. maybe look into the terminal/console whats prompted there.
i experienced the same problem once i tried the octane demo on a macbook but didnt know how to solve this.
may be some mac users must know how to setup the path/bin correctly under osx...
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
neutrinox
Thank You dave62!!! I'm not sure the export works because no error message came out, but the octane software didn't startup. Neither the terminal windows showed up. I change the folder name "/Applications/OctaneRender.app/Contents/MacOS/octane" but still not working.
yoyoz
You have to start blender from a terminal in order to get any logs.
Can you please give a try?
Yoyoz
mib2berlin
Hi, i have download a file from blendswap.com with an included hdr file.
I forgot to change the path of the hdr image and the exporter stops with an error message. clear.
After change the path and delete the temp files the exporter stops with the same error. ?
I delete the image in blender save the .blend, reopen blender, set the correct path but no way.
I delete the folder, unzip the blend to a new partition change path, get the same error.
Octane plug-in v1.10 on 2.56.6.36010 : Copying file "/home/pepo/d:/FD/Studio_HDR_giveaway_by_zbyg/studio011.hdr" to "/home/pepo/Bugatti/studio011.hdr"
Traceback (most recent call last):
File "/home/pepo/zwei5new/install/linux2/2.56/scripts/addons/octanerender/engine.py", line 99, in render
write_mtl(mtlTemp, mtl_list, scene, octane_render.export_copy_images)
File "/home/pepo/zwei5new/install/linux2/2.56/scripts/addons/octanerender/export.py", line 241, in write_mtl
filename = copy_image(mtex.texture.image)
File "/home/pepo/zwei5new/install/linux2/2.56/scripts/addons/octanerender/export.py", line 151, in copy_image
copy_file(fn_full,fn_dest)
File "/home/pepo/zwei5new/install/linux2/2.56/scripts/addons/octanerender/utils.py", line 113, in copy_file
file = open(source, 'rb')
IOError: [Errno 2] No such file or directory: '/home/pepo/d:/FD/Studio_HDR_giveaway_by_zbyg/studio011.hdr'
location:/home/pepo/zwei5new/install/linux2/2.56/scripts/modules/bpy/ops.py:179
Where store blender the information when i delete the world texture with shift/delete, i cant get it to work.
I also try to delete the whole world. :)
Cheers mib
http://www.blendswap.com/3D-models/vehi ... ti-veyron/
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
SamCameron
Is it possible to use this plugin in 2.57 RC's?
mib2berlin
Yes.
Install the zip directly in user preferences > addons.
Cheers mib
SamCameron
mib2berlin wrote:Yes.
Cheers mib
Doesn't work to me. what version are you using of blender and the plugin? cause I'm using RC2 with the two 0.93 version of the plugin without success.
yoyoz
With RC2 you should use v1.09d of the plugin, which can be found here: http://www.refractivesoftware.com/forum ... =32&t=5662
Lionel
Return to “Blender”
