OctaneRender for Rhino 3.03.2 [OBSOLETE]
I have refreshed the installer at the top of this thread with:
3.0.20.65
- Compiled with Octane 3.00 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
Refracty
Hi Paul,
I experience full Rhino crashes when the plugin is not loaded (un-ticked in the plugin options).
System: official V3 build with new Rhino V3 plugin release, latest Nvidia Driver and Quadro K6000 win 64 bit
If the plugin is not loaded, then it would not be the plugin causing the crash. Do you have a crash report on your desktop?
Refracty
This happened at a client machine. I can not say if I can access and send a crash report at the moment.
If Rhino is crashing when the plugin is NOT loaded...then it doesn't seem Octane related. I would need to see the crash report to give any more details.
I have updated the installer at the top of this thread with:
3.0.22.66 (8-Jun-2016)
- Compiled with Octane 3.01 (3.0.22)
- EXPERIMENTAL: Added the ability to convert an Octane Material to a NodeGraph type, which can be edited in the Octane node graph window. See https://youtu.be/Yd7jkAnRZpg for details.
- Fixed issue causing the FOV to be calculated incorrrectly when Safe Frame was enabled in Rhino
- "Int" nodes can no longer be converted to "Int Resolution" nodes
- Fixed some issues related to converting of the old resolution node to the new film settings resolution node
- Added new authentication settings window which can be used to activate, and de-activate the plugin
- You can now disconnect the Medium from the Environment Medium pin
prehabitat
face_off wrote:- EXPERIMENTAL: Added the ability to convert an Octane Material to a NodeGraph type, which can be edited in the Octane node graph window. See https://youtu.be/Yd7jkAnRZpg for details.
Woah, this is cool! time to upgrade!
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
Refracty
Paul, you are the best.
v-cube
Refracty wrote:Paul, you are the best.
indeed!
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
franchais
Thx Paul, Node graph is great!
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
Return to “Rhinoceros 3D”
