OctaneRender 2020 for DAZ Studio [TEST and STABLE][OBSOLETE]
Moderator: BK
Its not the subscribtion one!
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
Hi,face_off wrote:...
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
regarding the quoted point.
This issue is still present in the 2020.2RC2 build. Are there any announcements to tackle this problem. Are there any other workarounds than scaleing, moving or morphing? Its not always possible, because most of the mesh (for example wild generated eyebrowse) would hover over the base-mesh after adjusting. Kinde hard and very time consuming do this for high detailed eyebrows or intersecting hair-stripes. Is there some way to 'auto-bool' manifold meshes based on their normales?
Well aint that just greedy!
So i recently started trying the AI-Upsampler and ever so often when I change the Upsampler Mode (to 2x2) Daz Studio crashes on me. Its not happening every time but it happend like 4 or 5 times already. I'm not sure how to exactly replicate it to make it crash every time but i will try to play around a bit more. Not sure if it really is a bug or something on my side, just thought it could be worth mentioning.
It has been happening to me as well for ages now. I have noticed that it only happens if I try to do the switch while I have rendered something previously, or the application has been running for a while. If I do it as soon as I start (load a scene) without rendering anything at all before that, it works just fine.Banti wrote:So i recently started trying the AI-Upsampler and ever so often when I change the Upsampler Mode (to 2x2) Daz Studio crashes on me. Its not happening every time but it happend like 4 or 5 times already. I'm not sure how to exactly replicate it to make it crash every time but i will try to play around a bit more. Not sure if it really is a bug or something on my side, just thought it could be worth mentioning.
- Hun73rdk_1
So just had a ton of problem with Octane and animations the animation moved good in the timeline but when i was using octane to render the animation only the camera was moving everything else was static i had to render all frames one my one and rebuild the scene everytime i moved the time line anyone had the problem before ???
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
