Which feature do you need the most?
Region Render
139
6%
Network render
85
4%
Render Passes
239
11%
Hair&Fur
287
13%
Particles
229
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
88
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
369
16%
Mixing of daylight and HDRI environment
213
9%
Subdivision surfaces (OpenSubDiv)
80
4%
Multi UV channels
129
6%
Rounded edges
130
6%
Total votes: 2248
Polygons
Light caches. Light caches are essential for interior renderings as brute pathtracing returns very noisy results. Vray added this in 3.0 to Vray RT and it's hugely useful.
Better rounded edge shader. Again, Vray's is flawless, i use it on all my mechanical renderings, and with octane i haven't used it once as it's extremely limited in comparison and basically just creates massive artifacting on meshes
whersmy
PT with giclamp+causticblur+optimised emitters does a good job too
any good lightcaches comparisons and pathtracing out there?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
whersmy
I just came up with one, saw it hovering on the forums a few times ;) I need this now the most:
"render region per object"
I think that`s what`s it called.
**I personally dont really like hotpixal removal as it can also remove details, but that one also works
3dgeeks
LUT pass - I had suggested a postprocess or imager pass, but now think that making an LUT exporter is the only way to achieve this. I really like what I can achieve using the Octane imager but there appears to be no way to get these settings to PS or AE when using Linear.
mbetke
Physical camera please. :)
PURE3D Visualisierungen
sdanaher
Easy choice: the efficient handling of many small light sources without noise
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
Goldorak
sdanaher wrote:Easy choice: the efficient handling of many small light sources without noise
Yup. See my other post on this.
matrix2012
Physical Camera +1 :)
matrix2012
ORBX import.
Import Geometry, Texture, Lights ... ORBX for all 3D plugins would be great. :D
kostache
once again, please, make a render boolean node, like in MODO or Lightwave DP kit! It's only a thing, that prevent me to make all animations in Octane. Could you, please, at least, give any forecasts about when it be possible to make?
