******* Wishlist and feedback topic ********
dbalzer wrote:Hi Achmed,
A little but very helpful thing would be to be able to re-name Octane tags. When I for example animate properties of several light tags I'd have identical names within timeline and it becomes difficult to keep being organized. Possible fix?
Dan
I'd prefer "Ahmet". I have checked that seems like working!!?? Regards!
dbalzer
Dan
My apologies for spelling mistake Ahmed.
It seems the light tag doesn't have this option, though. I am using latest 2.25 R2
Windows 8.1/Cinema4D R16/1x GTX 980Ti + external GPU expander with 2x GTX 980Ti's and 2x GTX 970's
dbalzer,
i'll add this to V3. But at the end of tabs to avoid to see first when selected. Also best is to work with latest versions. If you change res file with this it will work on you. it's under res/description
OctaneLightTag.zip
(646 Bytes) Downloaded 285 times
dbalzer
aoktar wrote:dbalzer,
Yes, great stuff!!! Thank you Ahmed!
ratata
Hey aoktar,
just checking if there is news on vertex map support, this would be a great benefit now with houdini engine support in c4d, but we can transfer shader info only by vertex maps =)
Thanks.
http://www.twitter.com/sandidolsak
6850k|64gb|4 x GTX980ti
dbalzer
ratata wrote:Hey aoktar,
Thanks.
+1
thomastraum
Vertex Maps +1
DinoMuhic
Hey Ahmet,
would it be possible to implement "Invert X / invert Y / inver Z" buttons for the normal maps? That's pretty common in most renderers and applications. I really miss this a lot!
miroof
Hello,
Be able to keyframe the Volume step lengh could be a good thing.
| i7 3930K @4.6Ghz | ASUS RAMPAGE XTREM | 32 Go DDR3/2400 | 2x 660 GTX TI OC |
Janmansilver
Vertex Maps +1
Return to “User requests”
