OctaneRender for Rhino 3.03.2 [OBSOLETE]
neiwei845458454
http://files.mcneel.com/dujour/exe/2016 ... .13071.msi this is the rhinov6 download link. wish help you. thx
That's the Chinese version.
Try: http://www.rhino3d.com/download/rhino-sdk/wip
For the latest SDK (link copied from http://discourse.mcneel.com/t/rhino-wip ... able/30214 )
And the V6 WIP: http://www.rhino3d.com/download/rhino/wip (have to use a browser other than IE)
On my phone it takes me to a page where you enter your email address and RH50 key....
I am getting Serer Failed whenever I try to download the installer from there.
neiwei845458454
oh,im sorry.
http://files.mcneel.com/dujour/exe/2016 ... .13071.msi this is the english version.
For the adventurous, who also have access to Rhino6 WIP, you can try https://render.otoy.com/customerdownloa ... 0_6_62.rhi. It needs Rhino 6 build 6.0.16068. It may not work with builds after that. There are no new features available at this point in RhinoCommon - so it will have the same functionality as the Rhino5 plugin. Pls note that this version /replaces/ the Rhino5 plugin, so if you run Rhino5, you will need to reinstall the Rhino5 version of the plugin.
v-cube
... but it won't affect the 2.xx rhino 5 plugin right?
This way we could have Rhino 6 WIP combined with Octane for Rhino 3.xx beta and regular Rhino 5 with octane for Rhino 2.xxx side by side (which would be very nice IMHO, R6Wip for testing , R5 for stable production....
best
Andreas
face_off wrote:For the adventurous, who also have access to Rhino6 WIP, you can try https://render.otoy.com/customerdownloa ... 0_6_62.rhi. It needs Rhino 6 build 6.0.16068. It may not work with builds after that. There are no new features available at this point in RhinoCommon - so it will have the same functionality as the Rhino5 plugin. Pls note that this version /replaces/ the Rhino5 plugin, so if you run Rhino5, you will need to reinstall the Rhino5 version of the plugin.
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Hi Andreas, it /overwrites/ your Rhino5 plugin, so you cannot currently have both the Rhino5 and Rhino6 plugins installed. I may be able to change this in the future - I will check.
prehabitat
Perhaps with a non-standard V6 install it could be done?
Surely v6 doesn't rely on any v6 shared dll's/files? (Maybe naive)
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
This may not be correct. I cannot test on my development environment, however Rhino may actually handle both Rhino5 and Rhino 6 versions of the plugin together (since it /may/ store them in separate folders) - is someone able to try this and report back pls?
neiwei845458454
Hi Paul,
when I update to the octanerender for rhino v2.24 to v3.x released, how much should I pay for this? or I only need pay for v3.x stand-alone released and I dont pay for plugins of rhino.
How about this?
Alxen
How about this?
I don't know Alxen. I'm sure Otoy will make an announcement regarding this shortly.
Return to “Rhinoceros 3D”
