Beta 2.2 RC1: 3Ds Max plugin testing thread
Sauger
I´m very happy with the plugin, it´s working very nice with everything else then GhostTown ;)
It´s importing perfect manually, assigning uv´s with the right absurd Max tile values.
Can you take a look at some Cityscape fbx files (be happy to send you)!, since they import perfect to Octane via your script.
If GT can work effortless with Octane it will be a winner, the power of Octane with landscapes is amazeing, seems to not care of stuff that bring Vue/Max/Maxwell to a muddy slowmo.
All of them are useing instancing, perhaps the speed will drop with many reflective/transparent/AA proxy´s, I´m not the genious though (thank God).
I´m very happy with the state of both Octane/GT, if you don´t push the limits it´s rock solid.
3x I7/16gb/GTX570/XFX5870/GTX Titan
dox
Hello, I write this post bcs atm Im unable to make my project. I render few frames and crash, restarting all 10 frames crash again, sometimes more frames sometimes less i cant put my pc on night to render ..
Im rendering a scene from 3ds max 2012 64bit on Win7 64bit using Max2Octane Plugin 1.022h version and Octane 1.0 beta 2.46b. All seems to work perfectly good when i click render animations it rendering animation...
after few renders sometimes 1-40~ Octane crash (stop working at the program start, on other post ppl was talking about deallocate the memory on graphic card problem) and 3ds max going idle.
I didnt have that problem on single scene's, it crash only on rendering animations.
I was also testing project on Max2Octane plugin with line added in loop to make a sleep after next frame to "give time gpu to delocate memory" i have added 20s sleep still same problem it crash.
Dose anyone else have same problem on animations, or someone know what is going on here wrong ?
Check out topic "Maya plugin has more stability than Max2Octane... Why?" ppl there have same problems...
acestudio
Can't see the plugin link to download, could you help me?
Alessandro NC
Brasil
Core 17 [email protected] ghz | 16 gb ram | Windows 7 | Geforce GTX 580 1536
Return to “Autodesk 3Ds Max”
