Beta 2.2 RC1: 3Ds Max plugin testing thread
[gk]
jbeau3d wrote:
[gk] wrote:I have already started on a material converter and a octane mat lib combined.
Octane doesnt suport anything but a direct light, the script can be altered to accept vray, brazil, any specific light as well ofcourse.
I was just curious on the status of these scripts, no pressure:)
This havent been done yet, Ive had other things to attend so far.
Its piped, though not on top of todo list :)
Amiga 1000 with 2mb memory card
jbeau3d
I shaded my scene in octane, saved it, reloaded the file as animation. It got through 14 frames out of 700+ before crashing. Now whenever I try to reload the animation it loads but Octane asks me to locate the mesh file 3 different times before it loads properly. It does this on every frame. It also does this even if I try to render a single frame.
3dsmax9 x64
octane2max 1.022c
Octane build 1.022beta2.2b
Win7-X64 | Cubix 2x GTX 480 + QuadroFX 4600 PhysX | Dual-Quad W5590 | 12GB
simmsimaging
having some problems with the exporter (I think). Getting the normals problem that seems to come from having improper scene units, but I have set the scene in Max to meters. If I export/import manually it seems okay, but via the script it is causing problems. I posted about it here:
http://www.refractivesoftware.com/forum ... =33&t=3594
http://www.simmsimaging.com
blog.simmsimaging.com
i7 980 24GB Ram GTX580 3GB Vista 64 Ultimate
justix
2011 compatible?
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
kilaD
ok so you got it working?
Hello
evrinc
will the 2.2 RC1 plugin work with the latest Octane preBeta2.3 v5?
watanabe
evrinc wrote:will the 2.2 RC1 plugin work with the latest Octane preBeta2.3 v5?
same question, having issues here.
mATX renderbox: i7 [email protected] | Galaxy GTX480 SLI | Asus Rampage Gene III | 24GB G.Skill RAM | 60GB+120GB Vertex2 | Win7 x64 + 280.26
kilaD
what issues exactly?
Hello
Cronicash
Same issue....
EVGA sr2 2x x5650 12c/24t| 64Gbddr3 1600mhz | 4x gtx580 3gb on h20|4x 128x corsair ssd | 2x Strider 1500watt + 500watt |swiftech Blocks ,3x quad rads + dual rad (two loops)||8Tb|Laptop:Dell XPS 1730| 4Gb| 2x 9800GTX sli
Portfolio/blog
Cronicash
Okay so, .obj file different name from the .ocs gives you an "automation error" Still load saved .ocs though (whilst you can still just press okay and carry on, doing every frame manually and having to save img names in sequence. Very daunting).
Make .obj & .ocs file the same name then all it seems to do is keep loading the default material file and not loading the saved/ edited .ocs file...
Can you please at least load up some of the older plugins again to work with the previous versions of octane that worked (just so i can get some work out of the way...)
Sadly i dont have any previous ones saved...
I have done earlier render animations so i know it works...
http://www.refractivesoftware.com/forum ... om+fitting
Portfolio/blog
Return to “Autodesk 3Ds Max”
