Thx for very informative post!!! Please try to post somethings better, some images or scenes for next times. But i see there is an error message about singular matrixes. Always try to be away from using Scale=0 for any axis of scaling.mrom wrote:hello,
I dont understand, why octane suddenly doesn't show anything in the live viewer at frame 377 (everything works well till frame 376). I want to scale a cube in the z dimension with blackbody emission texture on 2 polys, but after a certain value (around 65) somehow it doesn't work anymore.
Log shows
Singular matrix:
-0.000 -0.000 -65.208 0.000
-0.000 1.000 -0.000 0.676
0.010 0.000 -0.000 -0.000
plugin already locked the result!
I kicked everything out of the scene, there is nothing really in it. Could be a bug?
sorry: win 7 64, r17.048, alpha 6 both plugin and standalone. latest cuda 7.5.18, 780ti and 780 3gb
Version 3.00 - Alpha10.1 (30.04.2016)
Got it! Anyway would be nice to see a sample scene maybe to fix it. Here is added a warning about possible same issue. It's a Renderer related topic and i'm not sure that's possible to fix without loosing performance.mrom wrote:Oh, I've edited my post 3 times after posting the original one, please look againSomehow it didn't take my scene.
At the bottom line.
viewtopic.php?f=30&t=40997
Thank you.
I found out something (and there is a sample scene attached to my first post, I don't know if you have seen it).
Just confirmed (changed the scaling to 2 instead of 0.01): It seems 0.01 is considered 0 and outputs the singular matrix and "plugin already locked the result" - why this occurs at frame 377 and not earlier, I don't know.
No scaled dimension is ever 0 (x scaling goes down to 0.01 though). And the error appears when scaling Z - somewhere in the area around value 65. Strange!Always try to be away from using Scale=0 for any axis of scaling.
Post a scene if you want to know. So we can check what happens. But that's clear matrix has strange values.why this occurs at frame 377 and not earlier
I still don't know if you have seen it:
Sample scene is attached here viewtopic.php?f=85&t=51856&start=220#p268415 (it is in your first quote already, too - I edited the post immediately after realising that it didn't attach the scene).
and changing the x scale value from 0.01 to 0.013 or something bigger changes the frame number, where the render disappears (so it's not 377, but a few frames later).
I attach the scene again here
Thank you very much!
- Attachments
- frame 377 disappear.rar
- (80.64 KiB) Downloaded 259 times
I'm checking...mrom wrote:I still don't know if you have seen it:
Alpha 6.1 build is available. Enjoy it!
YES!
BTW - Just so you'll know, i'm working with those alpha versions on production and it''s pretty stable.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
Also, what is the problem on mix materials that been fixed?
https://yambo.me
https://yambo.me
