OctaneRender 3 for Revit [OBSOLETE]
the installer search for Revit 2017 Architecture... I think that now there is only one Revit (no mep, architecture, str)
Good point - I will change this.
Garquitectos
With 3.0 "final" version I cant activate the plugin...
I have updated the revit plugin and the standalone (no more archicad :( ji, ji) What can I try? desactivate and activate again?
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Try going into Standalone->Preferences and Logout, then try to run the Revit plugin.
Cosoli
Garquitectos wrote:With 3.0 "final" version I cant activate the plugin...
I have updated the revit plugin and the standalone (no more archicad ji, ji) What can I try? desactivate and activate again?
Me too....... :cry:
face_off wrote:Try going into Standalone->Preferences and Logout, then try to run the Revit plugin.
I have tried, but it didn't work........
I will release the Octane 3.0 version of the plugin in the next 24hrs, which will hopefully resolves these issues.
I have updated the installers at the top of this thread with:
3.0.20.40
- Compiled with Octane 3.0 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
- "Int" nodes can no longer be converted to "Int Resolution" nodes
You will need an Octane 3.0 license in order to use this version of the plugin.
Seekerfinder
Thanks Paul.
Is there a particular reason Win 10 is not listed as being supported?
Seeker
First post updated to include Windows 10 - thanks Seeker.
Garquitectos
Hi Paul! I have a ramdon error... "error in SetOctaneApiNodeValue - null Octane node for pin node resolution" and then lost materials, cameras....
Another error in proxy when the scale factor is near to 0 popup another error... null matrix... or something
This looks like a problem related to the Resolution being moved into the Film Settings node. If you can work out how to re-produce the error, I will fix it.
Return to “Autodesk Revit”
