OctaneRender 3 for Revit [OBSOLETE]
Forums: OctaneRender 3 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Re: OctaneRender for Revit 3.0.10 [TEST]
Postby face_off » Fri May 06, 2016 12:12 pm
face_off Fri May 06, 2016 12:12 pm
the installer search for Revit 2017 Architecture... I think that now there is only one Revit (no mep, architecture, str)
Good point - I will change this.
Postby Garquitectos » Mon May 23, 2016 11:36 am
Garquitectos Mon May 23, 2016 11:36 am
With 3.0 "final" version I cant activate the plugin...
I have updated the revit plugin and the standalone (no more archicad :( ji, ji) What can I try? desactivate and activate again?
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Garquitectos
Postby face_off » Mon May 23, 2016 11:40 am
face_off Mon May 23, 2016 11:40 am
Try going into Standalone->Preferences and Logout, then try to run the Revit plugin.
Postby Cosoli » Tue May 24, 2016 4:37 am
Cosoli Tue May 24, 2016 4:37 am
Garquitectos wrote:With 3.0 "final" version I cant activate the plugin...
I have updated the revit plugin and the standalone (no more archicad ji, ji) What can I try? desactivate and activate again?
Me too....... :cry:
face_off wrote:Try going into Standalone->Preferences and Logout, then try to run the Revit plugin.
I have tried, but it didn't work........
Cosoli
Postby face_off » Tue May 24, 2016 6:55 am
face_off Tue May 24, 2016 6:55 am
I will release the Octane 3.0 version of the plugin in the next 24hrs, which will hopefully resolves these issues.
Re: OctaneRender for Revit 3.00 [TEST]
Postby face_off » Thu May 26, 2016 5:15 am
face_off Thu May 26, 2016 5:15 am
I have updated the installers at the top of this thread with:
3.0.20.40
- Compiled with Octane 3.0 (3.0.20)
- Fixed issue where the Reflections shadow pass was not working
- If you have ticked "Use offline licensing on this computer" when authenticating the plugin, you can now click the Deactive button on the OctaneLive tab to de-activate the plugin license
- "Int" nodes can no longer be converted to "Int Resolution" nodes
You will need an Octane 3.0 license in order to use this version of the plugin.
Postby Seekerfinder » Thu May 26, 2016 6:56 pm
Seekerfinder Thu May 26, 2016 6:56 pm
Thanks Paul.
Is there a particular reason Win 10 is not listed as being supported?
Seeker
Seekerfinder
Postby face_off » Thu May 26, 2016 11:38 pm
face_off Thu May 26, 2016 11:38 pm
First post updated to include Windows 10 - thanks Seeker.
Postby Garquitectos » Sun Jun 05, 2016 4:10 pm
Garquitectos Sun Jun 05, 2016 4:10 pm
Hi Paul! I have a ramdon error... "error in SetOctaneApiNodeValue - null Octane node for pin node resolution" and then lost materials, cameras....
Another error in proxy when the scale factor is near to 0 popup another error... null matrix... or something
Garquitectos
Postby face_off » Mon Jun 06, 2016 1:08 am
face_off Mon Jun 06, 2016 1:08 am
This looks like a problem related to the Resolution being moved into the Film Settings node. If you can work out how to re-produce the error, I will fix it.
PreviousNext
Return to Autodesk Revit
Wed Nov 25, 2020 10:25 pm [ UTC ]
