OctaneRender for Rhino 3.03.2 [OBSOLETE]
Dan
Thanks Paul. I'm not sure where to find that login info. All I see is my standalone license info on the liveoctane site
MacPro 3,1 | 2Quad Core Zeon 3 GHz | 16 GB | GTX 285 | Rhino, T-Splines, Octane
Hi Dan
Go to https://render.otoy.com/account/index.php? and select Licenses on the left menu - your Octane Standalone and Rhino licenses should then be listed. If not, pls contact Otoy directly to sort out the issue. Also - I notice you are on OSX - there is not currently an OSX version of the Rhino plugin.
I have refreshed the installer at the top of this thread with:
2.24.2.56
- Fixed exception resulting from saving the Rhino options when the OctaneRender Setup panel had not been opened
- Fixed exception when running the OctaneOpenViewport when the OctaneRender Setup panel had not been opened
pu235
Maybe this problem is not new or i´m the only one, but if i assign a material to an object that´s part of a layer with sublayers and the objects from the main and the sublayer are grouped - octane doesn´t show the material in the render view. Refreshing the viewport or restarting octane didn´t fix this. Rhino showed me that the material is assigned. After ungrouping and refreshing the viewport all thinks were ok.
Hi - I just tested this, and it worked OK for me - but perhaps our workflows are different. I tried...
1) Add 2 planes, assign the material for each to two layers, one layer being a sublayer of the other. Rendered OK
2) Selected the 2 planes and Edit->Groups->Group. Rendered OK
pu235
I tried to create the problem again- but now all works perfect.
3.0.0.57
- Compiled with Octane 3.0.0
- Added Medium and Medium Radius to the Daylight and Texture Environment settings
- Added new Render Passes
- Removed "Ambient" and "Sample Environment" GI Modes from the Direct Light kernel
- Added Deep Image settings to the kernel settings
- Added support for VDB files (add them in proxy ORBX files)
2.24.2.56
As this is the first Octane 3 build of the Rhino plugin, exercise caution and keep backup of the 2.24.2 versions of your scenes.
prehabitat
BOOM! Well done Paul :)
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
gabrielefx
what means compiled with Octane 3.0???
v-cube
:D :D :D :D :D :D :D :D :D
downloading.....
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Return to “Rhinoceros 3D”
