OctaneRender™ 2020.1 XB1 [superseded by 2020.1 XB2]
GillesKontrol
Any idea when network rendering is going to be a possibility again?
I would love to try rendering my scenes on my node without having to export them all the time.
On the standalone I cannot get multipass rendering to render as well, it just gets stuck at the end of the first frame and doesn't move on to the next frame.
Also for some scenes, when RTX is off, the scene renders fine. When RTX is on, the frame comes out as completly black. They're all exported from the C4D 2020 Plugin.
divasoft
GillesKontrol wrote:Any idea when network rendering is going to be a possibility again?
+1 we need network slave as fast as possible.
funk
I just posted this bug in the 2019.1.4 thread, but it also affects 2020.1 XB1
viewtopic.php?p=374501#p374501 (see post for OCS file)
Layered materials dont seem to work correctly if you have a layer, and the BASE MATERIAL pin comes from a MIX or COMPOSITE material
TRRazor
There seems to be a problem with alpha-mapped objects casting shadows onto random walk sss-enabled geometry.
The shadow in this scene shouldn't be visible, since that part of the alpha map (read: the haircap) is transparent. Yet, it is casting a shadow.
linograndiotoy
Would it be possible to add an AutoBump value to the Vertex Displacement node? That's something that needs to be controlled by the user (especially considering that Vertex Displacement is totally ignoring any texture connected to the Bump input of the material right now, as long as a procedural texture is used for displacement).
This is Vertex Displacement applied to a plane, with AutoBump off.
This is the same plane with AutoBump on.
Thanks!
Autobump.ocs
(78.21 KiB) Downloaded 373 times
osiosiosi
If i remember it correctly .. soeone allready mentioned it a time ago. What i would love to see is an option in daylight system to set the sun like i want it. Not by changing the time or location but just setting the sundirection with an arrow or something similar in 3d space. Its really bothering me sometimes to search for the sun and rotate it for minutes till i find an angle that looks good. I really dont care if its the "correct daytime, latitude or whatever ...
Would that be somehow possible?
Notiusweb
osiosiosi wrote:If i remember it correctly .. soeone allready mentioned it a time ago. What i would love to see is an option in daylight system to set the sun like i want it. Not by changing the time or location but just setting the sundirection with an arrow or something similar in 3d space. Its really bothering me sometimes to search for the sun and rotate it for minutes till i find an angle that looks good. I really dont care if its the "correct daytime, latitude or whatever ...
I think I may have been the one who mentioned this...like a X-Y-Z rotation gizmo for sun direction, right?
Otoy - I don't think anyone ever plots out time month, day, or any of that stuff. They just swirl the sun around till it looks good.
I am not saying to get rid of that stuff, but it is not really efficient for most users who don't care what time of the year it is.
I often wish I could take a placement node and put it on the sun and navigate it from there.
This makes a lot of sense to have.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
omardex
I think even if they are different software Otoy should take note of what the other developers are doing with their render engines, in my case I think they should explore how marmoset works with assets and elements in the viewport, and how software like substance designer handles nodes and connection ports or even the c4d plugin node editor is a step up (these giant nodes with a super small name are botering me), also those vertical node connections damage the read on the graph flow ... but these are just my opinions.
in general octane and marmoset are similar in the way that you import your geometry then light and prepare the look in the software, marmoset is "simpler" as is aimed at realtime preview, but it let you know what is happening in your scene at any time, you can see where your lights are, where they are aiming at, they are easy to select and work on, marmoset possibly never will achieve the scale and detail that octane provides but artist amaze with their work, the platform should and must ease this, not put obstacles in every corner, not every artist has the technical knowledge to know the month day or even year to put a sun, or even technical knowledge to code or solve the issues that doesn't require artistic eye, artist just want to create (of course this extra knowledge is beneficial but should not be necessary)
I dont know about software development, but a toggle overlay for object icons in the viewport or even a button to show wireframe will suffice to show where you elements are at, a toggle button for gizmos for elements such environments, projections (please this) and light directions will be extremelly useful.
marmoset also has something that working in conjunction with other software such photoshop or substance painter not a nightmare, reloading geometry and textures are done when you change programs windows, it simply updates the file when you get back to it.
anyway I think octane could be better, the small things are what the software is sloppy at, the software is a beast produces incredible good images with small effort, but when it get super technical I personally hit a wall.
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
karl
This is already possible - you can change the type of node used for a sun direction from "Sun direction" to "Float value" using the dropdown in the Node inspector and that allows you to specify any XYZ vector.
Notiusweb
I think we are looking for something a bit more simple and intuitive -
That Sun Direction X Y Z does not have a full 360 intuitive control set, like we do for HDRIs, with the X Y Z controls by themselves.
Unlike UV Transform in the placement node, the Sun Direction-Float Value only seems to traverse the coordinates 180 degrees, or up to a point. You cannot loop the X Y and Z with a single slider movement, let alone with a gizmo!
They have to be combined with all of the other sun controls.
It is PIA to work with in my opinion. Like I said, the sun map is great because it lets you swirl until you get to a look.
But, the precision control is not intuitive like a (1) gizmo & (2) full 360 "UV placement style" XYZ controls would be.
Plugs: Enterprise
