OctaneRender 4 / All Access - Update FAQ
Goldorak
BorisGoreta wrote:I just bought one 2018 license and network rendering is disabled.
If you bought the Enterprise AA pass, that should not the be the case for purchased plug-in. Studio subscriptions only support 20+ GPUS and netrender on V4, earlier and later releases are 1-2 GPUs max (for now). See viewtopic.php?f=33&t=70675&start=20
BorisGoreta
But the first sentence in this post says network rendering is disabled:
and yes I have OctaneRender® Enterprise All Access Bundle
BorisGoreta
OctaneRender_2018_1_RC4_win.exe does not install network rendering files at all !
BorisGoreta
This is what LW tells me when I want to go to Network Options:
Slaves are running:
This is my subscription:
BorisGoreta
I sorted this out. I installed subscription plugin version because I thought this is the one when you buy subscription ( which I did ). Instead I had to install regular plugin version and now it works.
SSmolak
BorisGoreta wrote:I sorted this out. I installed subscription plugin version because I thought this is the one when you buy subscription ( which I did ). Instead I had to install regular plugin version and now it works.
You have subscription version ( Studio ) or Enterprise ? If you have subscription you shouldn't install regular plugin version right ?
BorisGoreta
I had "standard" V4 and then upgraded to subscription 2018 since you can get 2018 and future version only by subscription route. But this new subscription is different from the previous subscription plan which I wasn't a part of. It is misleading I know, I had to install standard plugin and not the _vr plugin which is for previous subscription plan owners.
SSmolak
What is difference between Enterprise All Access and Enterprise without All Access ? Is OCR, additional network node, full Octane 2018 support works in not AA version ?
lovejunjie1
I have not used 3ds max any more. the license of 3dsMax is also meaningless. Could I spend a little more money and convert this license into other kinds? :?:
SSmolak
Final 2018.1 version is out. Can someone confirm how many GPUs studio version support ? Is there any RTX GPUs limitation ?
