Version 3.08.1-R4 (obsolete stable)
siha
not sure if this is a bug, but I found out, that OSL-Texture only compile when the material is applied to an object? Is this wanted?
cmittenaere
Thank you,
but I think it doesn't work with network render...
cmittenaere wrote:Thank you,
Hi Network rendering is working correctly with 3.08.1-R4, you need to install 3.08.1 daemon on the Slaves:
viewtopic.php?f=24&t=67352
ciao Beppe
eyeonestudio
Currently the Forester - Multi Cloner works well.
However, Display Points must be Off.
If you turn off Display Points, the viewport will be very slow.
This is got a lagging.
If you can get information from the Forester developer
Can render with Display Points on? (Like Scatter Object) :)
