Which feature do you need the most?
Region Render
139
6%
Network render
85
4%
Render Passes
239
11%
Hair&Fur
287
13%
Particles
229
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
88
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
370
16%
Mixing of daylight and HDRI environment
213
9%
Subdivision surfaces (OpenSubDiv)
81
4%
Multi UV channels
129
6%
Rounded edges
131
6%
Total votes: 2251
Garrick
A bridge to zbrush, like they have for keyshot. This would bring a lot of users to octane.
Vista 64| 660 GTX | 6600 Quad | 8GB DD2|Maya 2011
Synthercat
Volumetric light
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
HHbomb
@whersmy
"what does lightcache do? is it something like highlight compression?"
From chaosgroup (vray) "...light caching is similar in speed to the photon map and can produce approximations to the global lighting in a scene very quickly. In addition, the light cache can be used successfully for adding GI effects to animations...."
It could certainly help a lot to decrease the noise in interior rendering.
PolderAnimation
I realy would love uv baking. For light and also for textures.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
dionysiusmarquis
The list is all worked through with OR3, right? That's so awesome!
rappet
DayDreamer wrote:
rappet wrote:Should the poll not be setup again (or start new thread) without the features that in the meanwhile are already integrated?
This is a bright idea.
Still is :lol:
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
3dgeeks
When are the render slave licenses that Otoy said they are working on going to be available. I havent heard anything for a long time and now with Octane 3 coming out we will need to upgrade all our licenses including slaves.
riggles
3dgeeks wrote:When are the render slave licenses that Otoy said they are working on going to be available. I havent heard anything for a long time and now with Octane 3 coming out we will need to upgrade all our licenses including slaves.
I'd like to imagine that by the time Octane 3 is released and available for purchase, the network render licensing will be figured out.
used2bgordy
Hiya,
I'd like a check box in shader that would allow mask per material.
I don't mean per object, I mean per material.
I had something like that in SI until they killed it.
Artur
Goldorak
That is our plan. OpenCL CPU nodes already change things as was mentioned in the GTC talk. We need to see how things work once we get closer to final release or v3.
