Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
uncia
aoktar wrote:
uncia wrote:Here is a video about activation problem on Windows 8 and Cinema R 15.
http://we.tl/casBkAxXlo
ok, can't see any crash that you said about octane dialog. Btw, new logic is that. If you close octane dialog plugin will stop, is this a BUG?
This is just confusing logic. There is a button for pause render. I don't understand why rendering is stopping when you close Dialog window :?
And crashes had stoped when i deleted all preferences in appdata folder :)
Ok, a patch is coming for R15 problems. I hope that's going to work
pete1144
Yes Sir.....you've got this plugin working beautifully with r15. Congratulations...this is a great update! :)
pete1144 wrote:Yes Sir.....you've got this plugin working beautifully with r15. Congratulations...this is a great update! :)
Many Thanks,
it's far from my target, but we are on a good way.
For R15:
i discovered we have a language problem on non-english versions. And this patch is looking nice, i pray
http://render.otoy.com/customerdownload ... 4-099f.rar
http://render.otoy.com/customerdownload ... 5-099f.rar
shawnfrueh
Getting crashes when downloading live DB materials, and in some cases when I apply a DB material to an object it will crash. 0.99e
_BugReport (2).zip
(31.41 KiB) Downloaded 234 times
Pixelkingdom
Hi Aoktar,
i have one annoying bug with my mix materials. Mix Materials seems to work not correctly. When i adjust one texture slot the amount texture disappears. In some cases also the texture in slot 1 or slot 2 disappears! I have uploaded a project file and a video. Pleasse fix this :D . I had this bug in R13 and R15 on Windows 7. I tested the bug with only the octane plugin inside cinema 4d. No other plugins were active.
http://www.youtube.com/watch?v=Zl3BOqKxvVw
Greetz Pixelkingdom
octane_delete_slots.zip
(87.35 KiB) Downloaded 218 times
Win 7 64 bit//3xGTX TITAN//i7 980//12GB//Cinema 4D R15 Studio
http://www.kingsandchameleon.de
Pixelkingdom wrote:Hi Aoktar,
Greetz Pixelkingdom
thanks to c4d system. man it's know problem, you should manualy create nodes if you have problem. or enter the node to edit for solution
cfrank78
I use C4D Plugin on 3 Machines and did not have a crash since 5 days on any of them! Win 7, 64 bit, R15. Newest Nvidia driver! Applied about 100dreds of materials, own made materials, offline materials and online too! Maybe its a win 8 problem, i dont know. win 8 is crap anyway!
Pixelkingdom
I still got problems with mix materials.
The Node Editor doesnt work for me right now because i cant adjust the amount. There is no option to change settings. And when i use material editor.....the layer disappears.
Can u fix this bug soon? Would be nice. :)
https://www.youtube.com/watch?v=iLT_IkVGiIo
artdude12
Got a second license and tried Team Render using 0.99e.
It works fine for animations, but I can't it to render a single still image.
Is this not possible yet or am I not doing something right?
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
