Octane 2025.4 for Cinema4D - v1.7.2
Tim0042
ChrisHekman wrote: Fri Dec 19, 2025 12:56 pm Do you mean that it crashes to desktop (C4D application quits) or that Octane stops rendering?
Could you share a scene where it happens with? And steps to reproduce - even if it is inconsistent?
Sorry, I meant the latter, yep - C4D crashes to desktop. It does still show the standard "application error" message right before it closes (the one referencing bug reports and recovery scenes).
I can't share the scenes it currently happens with as these are work related, unfortunately, but I will try with some personal projects over the holidays and see if I can reproduce it. (Can I simply PM you a Google Drive link to a c4d file if I find something?)
Steps to reproduce: Currently, it seems to be just 1) render in the LV, 2) pause render, 3) switch to a different custom layout via the top right menu, 4) render again - and then sometimes it crashes, before any rendering starts. But it's not a reliable trigger. =/
@Tim0042
Have you tried to rebuild the custom layouts from scratch?
ciao,
Beppe
Tim0042
bepeg4d wrote: Fri Dec 19, 2025 3:22 pm @Tim0042
ciao,
Beppe
Ah, good point - some are indeed still from 2026.0. I've now done a test where I only jump back and forth between the standard layout and a new custom one, in a clean new scene with just a cube. After switching layouts and hitting the LV render button without issues six or seven times, C4D did eventually crash. This was when trying to start a render in the standard layout, curiously, so not even the custom one.
I will try again on my pc at home. For personal stuff, I could also switch to the Octane 2026 plugin, but at work we'll likely be on this version here until the current project is done. =/
Tim0042 wrote: Fri Dec 19, 2025 4:36 pm
ciao,
Beppe
Ok, please use the following Nvidia tool:
https://developer.nvidia.com/cleanup-tool
Then please perform a clean installation of 581.29 Nvidia Studio driver:
https://www.nvidia.com/en-us/geforce/drivers/results/254262/
After rebooting, try again to do the same steps and report back, thanks.
ciao,
Beppe
