OctaneRender® 2026.1 Alpha 1
linograndiotoy
Primitives don't provide smoothing angle options. With FBX it works as long as smoothing is correctly defined in the DCC software berfore exporting the file.
Try to "Shade Smooth" the box in Blender, and it will work fine in Standalone.
J.C
Primitives don't provide smoothing angle options but they work with previous displacement type. Same with the fbx I provided.
Anyways. I'll wait for the next iteration of Octane 2026 to see if displacement has improved with next build.
System – Windows 11
tombyrom
linograndiotoy wrote:
It's still in development, but very impressive already:
https://www.instagram.com/p/DDEr5JWtmOt ... BiNWFlZA==
Once it works with other projections such as tri-planar(a must have) and box and it's as well optimized as current displacement it will be amazing I am sure!
Side by side a 2k displacement in 2026 almost looks as good as an 8k in 2025 minus some small detials and you don't get any jagged bits.
As for not needing to bake procedural textures that will be nice as well although not been a huge problem for me to be honest even with chaos textures
Elvissuperstar007
Meshlets - will it work with Itoo Forest pack?
abstrax
Elvissuperstar007 wrote:Meshlets - will it work with Itoo Forest pack?
It will probably not work well. I haven't seen the tree geometry myself, but I expect there to be many separate island in the mesh topology for the leafs, which can't be reduced in a sensible way as far as I know.
You are probably also thinking of instancing the heck out of the trees, this doesn't work too well either at the moment, since an instanced meshlet mesh will end up with a meshlet selection that makes sure that the triangles of all instances don't cover too many pixels each. So you end up with far away instances having way too many meshlets. However, this can most likely be improved and we will try to find a better solution for instanced meshlet meshes when we are done with all the basics.
Tugpsx
ricky_otoy wrote:
pixelmonk wrote:"Neural Rendering Modules and Nodes (experimental): Launch ML and Neural Filters locally or through the Render Network with integrated local and remote neural rendering within the Octane Node Graph." Where are those? I don't see them in 2026.1 Alpha 1.
That is under: "2026.1 Roadmap: New Features in Active Development"
As an option, can we use ComfyUI as the local AI?
jobigoud
Tugpsx wrote:As an option, can we use ComfyUI as the local AI?
Right now in the development version, yes, it can talk to a local ComfyUI install. We have a few test nodes working.
We are also planning on having a remote Comfy server option to make it easier. I don't know at this point if both will work in the released version, it may depend on demand. (For local it requires installing some custom nodes to Comfy).
Tugpsx
Sweet, would love to test this out.
Tugpsx
Anyone with a working sample of a MaterialX scene? curious on how to setup the nodes in Octane Standalone.
Tugpsx
J.C wrote:Primitives don't provide smoothing angle options but they work with previous displacement type. Same with the fbx I provided.
Here is a primitive exported from daz studio with the displacement sample applied in standalone.
Torus displacement Ship
displacement_Lino.orbx
Primitive to make a greeblie spaceship
(2.29 MiB) Downloaded 318 times
