OctaneRender® 2023.1.2
SSmolak
Fallow distance in Field texture (shape mode) doesn't works well. It can't be pushed out to larger distance from SDF object.
john_otoy
SSmolak wrote:Fallow distance in Field texture (shape mode) doesn't works well. It can't be pushed out to larger distance from SDF object.
Is this the same issue you've brought up before? We replied here viewtopic.php?p=425019#p425019, but it looks like C4D may be missing the required settings so you need to report this in the C4D forum.
SSmolak
Ok, it works fine in C4D, just this parameter is differently named. SDF is insane slow if it is visible using low voxel sizes. To make it usable with SDF Field Texture it would be great to have something like "hide" option. I tried Visibility options and Ray Switch but this doesn't work the same as hidding object.
SSmolak
Image adjustment node doesn't support 32bit images even if clamp is disabled, not only saturation but other parameters too :
john_otoy
SSmolak wrote:Image adjustment node doesn't support 32bit images even if clamp is disabled, not only saturation but other parameters too :
Please export your scene to ORBX and make sure you can reproduce this in standalone. If it still happens, please attach the ORBX.
SSmolak
Yes, the same. Please compare Color Correction to Image Adjustment. Also is there chance to increase max Saturation value in Color Correction node to 5 for example ?
john_otoy
Thanks for the scene
john_otoy
OctaneRender 2023.1.3 has been released: viewtopic.php?f=24&t=83348
Hesekiel2517
Hi there,
network rendering is great, but i noticed lately that there are areas which are far more noise than others and they don't clear up.
Is there something you can do about it? Btw. did not test it in 2023.1.3
Edit: here is what the noise pass looks like
john_otoy
Hesekiel2517 wrote:Hi there,
Can you try this in 2023.1.3 and PM the ORBX to me if you are still having issues?
