OctaneRender for DAZ Studio 2021.1.5 - 72 [OBSOLETE]
Moderator: BK
toby_a
toby_a wrote:
sudisk wrote: On a side note, could you explain what the "Fallback to source" entry does in the template? I've tried to use it as a 3rd option but it doesn't seem to be the case.
As far as I can tell, "Fallback to source" is just a third property to try if the first two weren't found. I can't see any special treatment of it.
I just spotted a bug that will have prevented the "Fallback to source" channel from working. In the next version it will really work as I described, as the third option to use if the first two fail.
Sorel
Hi Toby!
Could we possibly get the following added to the iray uber template options?
Detail Weight
Detail Normal Map
Detail Specular Roughness Mult
toby_a
Sorel wrote:Hi Toby!
Detail Weight
Detail Normal Map
The next version (due next week if all goes well) will include two features in template source property selection that will (hopefully) help you:
  • a dynamic list of all of the properties of the Daz materials associated with the surfaces that the Octane material is currently assigned to
  • a free-form text editor so you can specify the name of any Daz property even if it's not in the list
Is it important to you to be able to choose Iray Uber properties from the list even when the material is not currently assigned to a surface that uses the Iray Uber shader?
Sorel
Detail Weight
Detail Normal Map
Oh that sounds like it will be helpful!. Will test when it's released then.
delguy
Hi Devs,
Do you intend to move the plugin to 2022 version? Maybe with the stable version.
Hun73rdk_1
delguy wrote:Hi Devs,
He said there is a ton of work before he moves to 2022 probably gonna take a little longer
Also i say catching up to features of 2021 is more important than just build the plugin with 2022 and not get the features
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
toby_a
Yep. At this point I'm hoping to be finished with supporting the 2021.1 features in the next couple of months. Fingers crossed, there should be an initial 2022 build released while it's still 2022, but it will take a while before all the 2022 features are exposed in the plugin.
Toby.
toby_a
A new test build has been released: viewtopic.php?f=44&t=80340
Return to “DAZ Studio”
