OctaneRender 2020.2 LightWave Production build 2020.2.3.1
Perhaps this is not a bug, perhaps this is the normal operation of the denoiser at low light levels. It is hard to say. But it looks bad enough.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Lightwave 3d
- scooternva
- Contact:
The multi-thread extraction feature that was broken in build 2020.2.3 is still broken in 2020.2.3.1 if NVLink is enabled, but if I disable NVLink it seems to work OK. A typical scene that I am using for testing took 38 seconds to load before rendering began in OctaneRender 2019.1.4. It now consistently loads in about 30 seconds with multi-thread extraction, but only if NVLink is disabled. QUESTION: Does enabling multi-thread extraction do anything for me besides speeding up the start of the first frame? I am not noticing any significant decrease in wait times between frames on a multi-frame animation.
Unfortunately, the speed increases in 2020.2.3.1 seem to be limited to scene loading; "RTX mode" does not appear to do anything for improving render times on my scenes. The aforementioned test scene rendered a frame in 33 seconds in OctaneRender 2019.1.4. In OctaneRender 2020.2.3.1 with RTX off it still renders in about 33 seconds. With RTX mode on, it still renders in about 33 seconds. The 2020.2.3.1 render times are identical whether NVLink is on or off. And if it makes any difference, I'm running the studio 471.11 driver.
Octane 2020.2.3.1 | LightWave 2019.1.5 (3134) | Win10 Pro 19041.1052 | 2 x Gigabyte AORUS RTX 2080 Ti Xtreme w/NVLink | Gigabyte AORUS Xtreme X399 | AMD Ryzen 2950X | 64 GB RAM | SSDs: Samsung 970 PRO 512 GB + Seagate FireCuda 510 2 TB | blog.gammans.zone
