Cinema 4D - OctaneX PR11/PR14 builds(Updated on 22.04.2022)
Hi rondomingue,
please, open the scene, then go to c4doctane Settings/Other tab, and, at the bottom of the panel, enable all the Log option checkboxes.
Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Other tab, press the Generate log report button, and share the octanelog_report.zip file, thanks.
ciao Beppe
rondomingue
This a recent Log Report from a recent crash I had. Some of the time it's just panning around a scene but most of the time it's related to the Node Editor and mainly the Transform node.
Sorry the file was too large to use attachments so I used a Dropbox link.
http://www.dropbox.com/s/ebk9o7d1181occ ... t.zip?dl=0
Hi rondomingue
There is a known issue with AMD Navi GPUs (like your Radeon PRO 5700 XT) while working in 2D+3D.
The devs are working with Apple to fix the issue for the next version.
In the meantime, please try to create and edit the materials using the Attribute editor, instead of Node Editor, as much as possible.
ciao Beppe
Weezer
I asked this in the other OctaneX thread, but received zero response. So… Any news on the progress of OctaneX? I know stuff is happening behind the scenes, but what can we expect from the next release… and when?
rondomingue
Hi Beppe, Do we know if PR8 has the same issue PR11 with using the Node Editor in Cinema4D? (Willing to downgrade if it's more stable.) Or should we just look for the next release in MacOS Monterey? I'm assuming my AMD Radeon Pro 5700 XT cards will still be supported for Octane X and it's not one of the “older” cards. Thanks!
there is an issue in PR8 SDK with the demo mode that is starting after some time, so better to stick with PR11, for now.
ciao Beppe
rondomingue
I'm using the RNDR network to render scenes. I'm aware of the issue of exporting an .orbx file from Cinema 4D and dropping frames in Metal and used this solution https://www.youtube.com/watch?v=x7oSjaoanuw to export out of Terminal. However, I come across this error that prevents the .orbx export from Terminal.
FumeFx library initialisation error!
I don't have the FumeFx plug-in so I'm not sure what the solution is.
the FumeFX error is not important, it only shows that you don't have Fume FX library installed.
Please, copy paste the entire output in your answer.
ciao Beppe
rondomingue
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/asset.module.xlib with module(s) net.maxon.asset
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/c4d_viewport_nodegraph.module.xlib with module(s) net.maxon.c4d_viewport_nodegraph
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/c4dplugin.xlib with module(s) net.maxon.rlmlicensing net.maxon.c4d.c4dplugin
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/command.module.xlib with module(s) net.maxon.command
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/corenodes.module.xlib with module(s) net.maxon.corenodes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/crashhandler.module.xlib with module(s) net.maxon.crashhandler
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/crypt.module.xlib with module(s) net.maxon.crypt
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/denoiser.module.xlib with module(s) net.maxon.denoiser
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport.module.xlib with module(s) net.maxon.drawport
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport_functioncache.module.xlib with module(s) net.maxon.drawport_functioncache
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport_general.module.xlib with module(s) net.maxon.drawport_general
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport_metal.module.xlib with module(s) net.maxon.drawport_metal
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport_opengl.module.xlib with module(s) net.maxon.drawport_opengl
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/drawport_selector.module.xlib with module(s) net.maxon.drawport_selector
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/embree.module.xlib with module(s) net.maxon.embree
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/geom.module.xlib with module(s) net.maxon.geom
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/geometry_abstraction.module.xlib with module(s) net.maxon.geometry_abstraction
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/gui.module.xlib with module(s) net.maxon.gui
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/image.module.xlib with module(s) net.maxon.image
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/image_avfoundation.module.xlib with module(s) net.maxon.image_avfoundation
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/image_openexr.module.xlib with module(s) net.maxon.image_openexr
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/licensing.module.xlib with module(s) net.maxon.licensing
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/magicbulletlooks.module.xlib with module(s) net.maxon.magicbulletlooks
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/math.module.xlib with module(s) net.maxon.math
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mesh.module.xlib with module(s) net.maxon.mesh
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/misc.module.xlib with module(s) net.maxon.misc
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_base_presenter.module.xlib with module(s) net.maxon.mvp_base_presenter
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_base_view.module.xlib with module(s) net.maxon.mvp_base_view
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_desktop2d_nodegraph_widgets.module.xlib with module(s) net.maxon.mvp_desktop2d_nodegraph_widgets
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_desktop2d_widgets.module.xlib with module(s) net.maxon.mvp_desktop2d_widgets
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_nodegraph_presenters.module.xlib with module(s) net.maxon.mvp_nodegraph_presenters
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mvp_nodes_presenters.module.xlib with module(s) net.maxon.mvp_nodes_presenters
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/network.module.xlib with module(s) net.maxon.network
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/neutron.module.xlib with module(s) net.maxon.neutron
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/nodes.module.xlib with module(s) net.maxon.nodes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/nodes_corenodes.module.xlib with module(s) net.maxon.nodes_corenodes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/opensubdiv.module.xlib with module(s) net.maxon.opensubdiv
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/post.module.xlib with module(s) net.maxon.post
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/pythonconfig.module.xlib with module(s) net.maxon.pythonconfig
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/pythonvm.module.xlib with module(s) net.maxon.pythonvm
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/reflection.module.xlib with module(s) net.maxon.reflection
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/render.module.xlib with module(s) net.maxon.render
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/retargetbase.module.xlib with module(s) net.maxon.retargetbase
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/shaderbase.module.xlib with module(s) net.maxon.shaderbase
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/shadernodes.module.xlib with module(s) net.maxon.shadernodes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/svg.module.xlib with module(s) net.maxon.svg
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/tessellation.module.xlib with module(s) net.maxon.tessellation
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/usd.module.xlib with module(s) net.maxon.usd
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/cadexchangeconfig.xlib with module(s) net.maxon.c4d.cadexchangeconfig
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/houdiniconfig.xlib with module(s) net.maxon.c4d.houdiniconfig
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/substanceconfig.xlib with module(s) net.maxon.c4d.substanceconfig
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/addons.xlib with module(s) net.maxon.c4d.addons
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/advanced_render.xlib with module(s) net.maxon.c4d.advanced_render
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/alembic.xlib with module(s) net.maxon.c4d.alembic
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/archigrass.xlib with module(s) net.maxon.c4d.archigrass
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/bitmapfilter.xlib with module(s) net.maxon.c4d.bitmapfilter
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/bpexchange.xlib with module(s) net.maxon.c4d.bpexchange
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/browser.xlib with module(s) net.maxon.c4d.browser
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/bugslife_client.xlib with module(s) net.maxon.c4d.bugslife_client
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/c4d_viewport_render.xlib with module(s) net.maxon.c4d.c4d_viewport_render
Loading file:///Applications/Maxon Cinema 4D R23/plugins/c4doctane/c4doctane-R23.xlib with module(s) net.otoy.c4doctane
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/ca.xlib with module(s) net.maxon.c4d.ca
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/ca2.xlib with module(s) net.maxon.c4d.ca2
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/cadexchange.xlib with module(s) net.maxon.c4d.cadexchange
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/clothilde.xlib with module(s) net.maxon.c4d.clothilde
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/collada14.xlib with module(s) net.maxon.c4d.collada14
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/collada15.xlib with module(s) net.maxon.c4d.collada15
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/colorchoosergui.xlib with module(s) net.maxon.c4d.colorchoosergui
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/compositing.xlib with module(s) net.maxon.c4d.compositing
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/Cyc Types/cyctypes.xlib with module(s) com.greyscalegorilla.cyctypes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/deltamush.xlib with module(s) net.maxon.c4d.deltamush
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/deployment.xlib with module(s) net.maxon.c4d.deployment
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/DropZone/dropzone.xlib with module(s) com.greyscalegorilla.dropzone
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/dwg.xlib with module(s) net.maxon.c4d.dwg
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/dwgobjects.xlib with module(s) net.maxon.c4d.dwgobjects
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/dynamics.xlib with module(s) net.maxon.c4d.dynamics
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/exchanges.xlib with module(s) net.maxon.c4d.exchanges
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/expressiontag.xlib with module(s) net.maxon.c4d.expressiontag
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/fbx.xlib with module(s) net.maxon.c4d.fbx
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/gltf.xlib with module(s) net.maxon.c4d.gltf
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/GorillaCam/gorillacam.xlib with module(s) com.greyscalegorilla.gorillacam
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/goz.xlib with module(s) net.maxon.c4d.goz
Loading file:///Applications/Maxon Cinema 4D R23/plugins/osx_r23_greyscalegorillahub/greyscalegorillahub.xlib with module(s) com.greyscalegorilla.greyscalegorillahub
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/hair.xlib with module(s) net.maxon.c4d.hair
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/HDRI Link/hdrilink.xlib with module(s) com.greyscalegorilla.hdrilink
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/i_skp.xlib with module(s) net.maxon.c4d.i_skp
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/interop.xlib with module(s) net.maxon.c4d.interop
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/io_obj.xlib with module(s) net.maxon.c4d.io_obj
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/Light Kit Pro/lightkit3.xlib with module(s) com.greyscalegorilla.lightkit3
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/Light Types/lighttypes.xlib with module(s) com.greyscalegorilla.lighttypes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/metrics.xlib with module(s) net.maxon.c4d.metrics
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mkmodeler.xlib with module(s) net.maxon.c4d.mkmodeler
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mocca.xlib with module(s) net.maxon.c4d.mocca
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/model.xlib with module(s) net.maxon.c4d.model
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/mograph.xlib with module(s) net.maxon.c4d.mograph
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/motioncam.xlib with module(s) net.maxon.c4d.motioncam
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/motiontracker.xlib with module(s) net.maxon.c4d.motiontracker
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/nbo.xlib with module(s) net.maxon.c4d.nbo
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/nbp.xlib with module(s) net.maxon.c4d.nbp
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/newman.xlib with module(s) net.maxon.c4d.newman
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/nodeeditor.xlib with module(s) net.maxon.c4d.nodeeditor
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/objects.xlib with module(s) net.maxon.c4d.objects
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/onlineupdater.xlib with module(s) net.maxon.c4d.onlineupdater
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/PlusLibrary/pluslibrary.xlib with module(s) com.greyscalegorilla.pluslibrary
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/projectassetinspector.xlib with module(s) net.maxon.c4d.projectassetinspector
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/python.xlib with module(s) net.maxon.c4d.python
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/relaxuv.xlib with module(s) net.maxon.c4d.relaxuv
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/sculpt.xlib with module(s) net.maxon.c4d.sculpt
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/sculptbrushes.xlib with module(s) net.maxon.c4d.sculptbrushes
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/shader.xlib with module(s) net.maxon.c4d.shader
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/Signal/signal.xlib with module(s) com.greyscalegorilla.signal
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/sketch.xlib with module(s) net.maxon.c4d.sketch
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/sky.xlib with module(s) net.maxon.c4d.sky
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/sla.xlib with module(s) net.maxon.c4d.sla
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/spacemouse.xlib with module(s) net.maxon.c4d.spacemouse
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/substance.xlib with module(s) net.maxon.c4d.substance
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/teamrender.xlib with module(s) net.maxon.c4d.teamrender
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/thinking_particles.xlib with module(s) net.maxon.c4d.thinking_particles
Loading file:///Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/plugins/Greyscalegorilla/Topcoat/topcoat.xlib with module(s) com.greyscalegorilla.topcoat
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/tpoperators.xlib with module(s) net.maxon.c4d.tpoperators
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/usd.xlib with module(s) net.maxon.c4d.usd
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/uvviewport.xlib with module(s) net.maxon.c4d.uvviewport
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/volumes.xlib with module(s) net.maxon.c4d.volumes
WARNING: Error loading file:///Applications/Maxon Cinema 4D R23/plugins/X-Particles/X-Particles.xlib: symbol 'g_maxon' is missing. error: dlsym(0x7f89ad899170, g_maxon): symbol not found [osx_dll.cpp(148)] [general.cpp(401)]
WARNING: Error loading file:///Applications/Maxon Cinema 4D R23/plugins/X-Particles/X-Particles_21.xlib: file:///Applications/Maxon Cinema 4D R23/plugins/X-Particles/X-Particles_21.xlib has wrong binary version 21014, expected 23004. [osx_dll.cpp(173)] [general.cpp(401)]
Loading file:///Applications/Maxon Cinema 4D R23/plugins/X-Particles/X-Particles_23.xlib with module(s) ltd.insydium.xparticles
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/xpressocore.xlib with module(s) net.maxon.c4d.xpressocore
Loading file:///Applications/Maxon Cinema 4D R23/corelibs/xtensions.xlib with module(s) net.maxon.c4d.xtensions
Drawport API initialized
Framework : Metal
Vendor : AMD
Device : AMD Radeon Pro 5700 XT
Framework version: 2.2
Driver version : 2.2
DNS-Redirection detected. Filter set for 1 IPs:
> 23.202.231.169
delete file:bugreport_20210918_202304.zip
Creating zip file:/Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/_bugreports/octane/bugreport_20210920_110142.zip
Adding file:/Users/rdomingue/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/c4doctanelog.txt
Loaded Octane DLL:Octane X Studio PR11 version:10000306 SDK:PR11
Octane X for Cinema 4D PR11 built for:230 C4D vers:23008
C4D:23008 comp:[rdomingue-imac] OS:[OS X 64 BIT] OS X: Version 10.16 (Build 20G95) versType:10
CPU:[GenuineIntel, stepping 5, model 5, instruction family 6] speed:3.8 GHz numOfCpu:16Ht
Plugins:[houdiniconfig addons advanced_render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4doctane-R23 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing cyctypes deltamush deployment dropzone dwg dwgobjects dynamics exchanges expressiontag fbx gltf gorillacam goz greyscalegorillahub hair hdrilink i_skp interop io_obj lightkit3 lighttypes metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater pluslibrary projectassetinspector python relaxuv sculpt sculptbrushes shader signal sketch sky sla spacemouse substance teamrender thinking_particles topcoat tpoperators usd uvviewport volumes X-Particles_23 xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D R23/plugins/c4doctane/res/osl_scripts
Cinema 4D Bridge Build 18 (c) INSYDIUM LTD : www.insydium.ltd
Registered to : Ron Domingue <[email protected]>
X-Particles Build 895 Release
Tue Sep 08 13:05:16 2020
Copyright (c) INSYDIUM LTD
Registered To : Ron Domingue <[email protected]>
HDRI Studio Rig V(2.152) - for R23+
Export orbx:/Volumes/NEXUS 8/Dropbox (Personal)/00 - 3D/00Models/CHARACTERS/R2-D2/R2_D2_02.c4d start:-1 end:-1 step:0
Quixel Bridge Plugin::Error Line : 59 OSError [Errno 48] Address already in use
Deleting texCache folder... /Users/rdomingue/Library/OctaneRender/cache/texCache
VRAM used/free/max:0Kb/15.984Gb/15.984Gb Out-of-core used:0Kb RAM used:28.484Gb total:32Gb OpenGL free/total:0/0
1-Start Orbx Export....
<< exportAnimatedORBX >>
--------------------------- EXPORT LOG ---------------------------
ResetAndInit 1
ResetAndInit [OK]
Multi-threaded material conversion, thread count=14
[/code]
