OctaneX Studio/Enterprise PR7 for BigSur
Goldorak
m0dm0d wrote:Not having any luck this end (with M1 Macbook Air).
Application Specific Information:
/Users/xxx/Library/Preferences/Maxon/Maxon Cinema 4D R21/plugins/c4doctane/liboctane.dylib
abort() called
Cinema 4D(751,0x20337be00) malloc: Heap corruption detected, free list is damaged at 0x600002469b20
*** Incorrect guard value: 10582850470324047192
(Macbook Air, Big Sur 11.1, C4D R21 (latest update), PR7 Studio)
Can you confirm standalone or blender work? What tier?
cjadams
Seems to have worked..
m0dm0d
Yes, standalone (Studio PR7) is working... just can't get anything to show up in C4D (app crashes at startup).
Thanks.
Janmansilver
Thanks.
Same for me on my MacBook Air M1. Stand Alone works fine, but plugin crashes Cinema.
Goldorak
Thanks.
Can you confirm if Blender or other plug-ins work on your M1 or if it is just C4D?
jamesbat420
not having any luck trying scenes i used on the catalina builds just fine...
this is the error,, please lmk if there is a fix. standalone pr7 is working fine also.
Loaded Octane DLL:Octane X Studio PR7 version:10000302 SDK:PR7
Octane X for Cinema 4D PR7 built for:230 C4D vers:23008
C4D:23008 comp:[james’s MacBook Pro] OS:[OS X 64 BIT] OS X: Version 10.16 (Build 20C69) versType:10
CPU:[GenuineIntel, stepping 10, model 14, instruction family 6] speed:2.6 GHz numOfCpu:12Ht
Plugins:[houdiniconfig addons advanced_render alembic archigrass bitmapfilter bpexchange browser bugslife_client c4d_viewport_render c4doctane-R23 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater projectassetinspector python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 89 osl scripts from dir:/Applications/Maxon Cinema 4D R23/plugins/OctaneX_PR7_Studio/res/osl_scripts
VRAM used/free/max:0Kb/3.984Gb/3.984Gb Out-of-core used:0Kb RAM used:14.303Gb total:16Gb OpenGL free/total:0/0
Scene created in plugin version 3060003
Scene plugin version is older than version:PR7
Plugin will convert the parameters of displacement texture.
Animated attributes should be changed by manually!
Convert OctaneDayLight medium thickness from:1 to:100
File not found:/Users/james/Library/Preferences/Maxon/Maxon Cinema 4D R23_2FE1299C/updates-ox.txt
FRAME:0 fps:30
docFrame:0 edRender:1 curFrame:0 From:0 To:0 rFps:30 docFps:30
Total time:7.384 ms. Estimated time:7.384 ms.
Calculation completed.... frames:[0-1]
FumeFx library initialisation error!
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=10
Export materials time= 44.731 ms
Collect objects time= 15.708 ms
Mesh creation time = 27.677 ms.
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Check geometry subdivisons.
Picture viewer uses 'Render' subdivisions. But Live Viewer uses 'Editor' subdivision values.
Try to decrease 'render/editor' subdivison values.
LVL:0 1 2
LVL:0 1 2
**** RENDER FINISHED **** stat=6
Goldorak
jamesbat420 wrote:not having any luck trying scenes i used on the catalina builds just fine...
FRAME:0 fps:30
LVL:0 1 2
LVL:0 1 2
Just to confirm, you are on Mac OS 11.1 correct?
jamesbat420
FRAME:0 fps:30
LVL:0 1 2
LVL:0 1 2
yep
and the latest c4d 23.1110
Goldorak
FRAME:0 fps:30
LVL:0 1 2
LVL:0 1 2
yep
Can you confirm the scene loads OK in 2020.1.5 on windows/cudaa c4D R23? If the scene was saved on Catalina (pre PR6) I wonder if there may be something that got messed up since those weren't dev builds. Can you even start a new scene in PR7 C4D?
jamesbat420
literally nothing works, even when i start the scene, been having to use arnold for now, but let me know when next release comes out as its annoying to pay for something that doesnt work lol, even reset my mac which took ages oof
