2020.1.5-R4 & RTX 3090 not working at all
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
lanklaf
analog wrote:So I did some tests on different heavy scenes i´m working on.
First thing I noticed is enabling RTX nearly halfs the Ms/sec. I know it depends on the scene but before working with the 3090 enabling RTX brought a huge boost on most of my projects.
Secondly I´m a little dissapointed of the performance. Working with two RTX 2080 was almost the same speed as working with a 3090 and a 2080. Not sure if I should keep the card.
Just saw that "Number of Cuda-Cores" is not showing for the 3090:
Could this be a problem?
P.S.: Temps are OK!
Do you have a priority mode set to "LOW"?
Uncheck "Use Priority" for RTX 3090.
System:
i7 8700K / RTX 2020 / 16GB RAM
P.S.: Temps are OK!
Nope, it is only a typo, if you open Standalone 2020-2-RC4, then go to File/Preferences/Devices, it should have been already fixed.
Try to use the latest Standalone also for testing rendering speed.
ciao Beppe
Return to “Bug Reports”
