OctaneRender™ 2020.2 RC2
vijay
pegot wrote:I opened a file that was about a year old and I am seeing an issue where denoising is rendering a text label much thinker than it should be.
The file renders correctly with denoising on Octane 2020.1.5.
The problem appears with latest Octane 2020.2 RC2.
If Devs need ORBX send me info where to upload that (archived file is about 1.12 GB).
Could you upload the ORBX to the google drive or drop box and pm me the link ?. I'll have a look at it.
Vijay
pegot
The attachment Octane-2020.2_RC2-Denoised.png is no longer available
The attachment Octane-2020.1.5-Denoised.png is no longer available
Would you be able to share a minimum repro case for this issue? You may share your file by the means that is most convenient for your and send a PM.
Thank you.
Mojave and vijay_thirukonda, see attached archive for file with the issue where text label shows much thicker when denoising is activated.
I also just tried it in 2020.2 RC3 and the problem persists.
NOTE: My file was so large before because I had animated textures for the water drops – but I cleared them all from the file animation box before saving out my ORBX. And even though they no longer showed in the animation, Octane still retained all those files. This was evident when I unpacked the ORBX just now. So I don’t know if I didn’t clear out the files correctly, or if that might be a separate issue? Regardless, the file is at a more manageable size now.
LabSeries-IFM-Tube.7z
(72.27 MiB) Downloaded 371 times
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
